Hi!!!!
I have in long time tried to find out how to control pins on the Arduino with buttons or check box on a web site. I have an Arduino UNO with Ethernet shield. Can some one please tell me how to do it and give me a simple code for it.
Thanks!!!!!
Ps: Sorry for my bad English
html button test code.
//zoomkat 8-04-12
//simple button GET server code to control servo and arduino pins 5, 6, and 7
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use ' instead of " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
///note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
 pinMode(5, OUTPUT); //pin selected to control
 pinMode(6, OUTPUT); //pin selected to control
 pinMode(7, OUTPUT); //pin selected to control
 pinMode(8, OUTPUT); //pin selected to control
 //start Ethernet
 Ethernet.begin(mac, ip, gateway, gateway, subnet);
 server.begin();
 //enable serial data print
 Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
 // Create a client connection
 if (client) {
  while (client.connected()) {
   if (client.available()) {
    char c = client.read();
    //read char by char HTTP request
    if (readString.length() < 100) {
     //store characters to string
     readString += c;
     //Serial.print(c);
    //if HTTP request has ended
    if (c == '\n') {
     Serial.println(readString); //print to serial monitor for debuging
     client.println("HTTP/1.1 200 OK"); //send new page
     client.println("Content-Type: text/html");
     client.println();
     client.println("<HTML>");
     client.println("<HEAD>");
     client.println("<TITLE>Arduino GET test page</TITLE>");
     client.println("</HEAD>");
     client.println("<BODY>");
     client.println("<H1>Zoomkat's simple Arduino button</H1>");
    Â
     // For simple testing, pin 5, 6, 7, and 8 are used in buttons
     // DIY buttons
     client.println("<a href=/?on2 >ON</a>");
     client.println("<a href=/?off3 >OFF</a>");
     client.println(" <a href=/?off357 >ALL OFF</a>
     // mousedown buttons
     client.println("<input type=button value=ON onmousedown=location.href='/?on4;'>");
     client.println("<input type=button value=OFF onmousedown=location.href='/?off5;'>");   Â
     client.println(" <input type=button value='ALL OFF' onmousedown=location.href='/?off3579;'>
");Â Â Â Â
        Â
     // mousedown radio buttons
     client.println("<input type=radio onmousedown=location.href='/?on6;'>ON</>");
     client.println("<input type=radio onmousedown=location.href='/?off7;'>OFF</>");
     client.println(" <input type=radio onmousedown=location.href='/?off3579;'>ALL OFF</>
");Â Â
Â
    Â
     // custom buttons
     client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8;'>");
     client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9;'>");
     client.print(" <input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579;'>");
     client.println("</BODY>");
     client.println("</HTML>");
     delay(1);
     //stopping client
     client.stop();
     ///////////////////// control arduino pin
     if(readString.indexOf('2') >0)//checks for 2
      digitalWrite(5, HIGH);  // set pin 5 high
      Serial.println("Led 5 On");
     if(readString.indexOf('3') >0)//checks for 3
      digitalWrite(5, LOW);  // set pin 5 low
      Serial.println("Led 5 Off");
    Â
     if(readString.indexOf('4') >0)//checks for 4
      digitalWrite(6, HIGH);  // set pin 6 high
      Serial.println("Led 6 On");
     if(readString.indexOf('5') >0)//checks for 5
      digitalWrite(6, LOW);  // set pin 6 low
      Serial.println("Led 6 Off");
    Â
     if(readString.indexOf('6') >0)//checks for 6
      digitalWrite(7, HIGH);  // set pin 7 high
      Serial.println("Led 7 On");
     if(readString.indexOf('7') >0)//checks for 7
      digitalWrite(7, LOW);  // set pin 7 low
      Serial.println("Led 7 Off");
     } Â
    Â
      if(readString.indexOf('8') >0)//checks for 8
      digitalWrite(8, HIGH);  // set pin 8 high
      Serial.println("Led 8 On");
     if(readString.indexOf('9') >0)//checks for 9
      digitalWrite(8, LOW);  // set pin 8 low
      Serial.println("Led 8 Off");
     }   Â
     Â
     //clearing string for next read
     readString="";
Thanks a lot!! It was in a big help :)
I tried the code and everything worked fine. But when I make the code little shorter with just one output and one set ON/OFF buttons nothing worked. The html site and all that stuff worked fine, but when I clicked on one of "ON" or "OFF" buttons nothing happens. Can some one pleas try to find what is wrong.
The code is:
#include <SPI.h>
byte ip[] = { 192, 168, 0, 177 };
byte gateway[] = { 192, 168, 0, 1 };
String readString;
 pinMode(5,OUTPUT);
Â
 server.begin();
 if (client) {
     readString += c;
     //Serial.print(c);
    if (c == '\n')
     client.println();
    Â
     client.println("<http>");
     client.println("<head>");
     client.println("<title>Hans Arduino</title>");
     client.println("</head>");
     client.println("<body>");
     client.println("<H1><u>Velkommen!!</U></H1>");
     client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?8;'>");
     client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?9;'>");
     client.println("</body>");
     client.println("</html>");
    Â
     delay(1);
     client.stop();
    Â
      digitalWrite(5, LOW);  // set pin 8 low
    Â
     readString="";
pleas help!!
Thanks!!!!
I found it, I had just digitalWrite wrong pin. ohffff I'm a big idiot hehe
