Help with expanding motor project. [SOLVED]
At the moment, I have programmed a stepper motor (on pins 10-13) to continually spin in a direction determined by wether "dir" is true or false.
I'm trying to get it to do the directions in a certain order, that being:
WAIT 3 SECONDS > TURN CLOCKWISE FOR 4 SECONDS > TURN ANTI-CLOCKWISE FOR 4 SECONDS > TURN OFF AGAIN
I'm pretty sure that using the "delay" function wouldn't be as effective, because using a delay would automatically stop everything, so the clockwise turning would be cancelled. But I have no idea how to use "millis" or if there is some local form of the delay function. Any ideas?
int Pin1 = 10;
int Pin2 = 11;
int Pin3 = 12;
int Pin4 = 13;
int _step = 0;
boolean dir = false;// false=clockwise, true=counter clockwise
int count=0;
 pinMode(Pin1, OUTPUT);
 pinMode(Pin2, OUTPUT);
 pinMode(Pin3, OUTPUT);
 pinMode(Pin4, OUTPUT);
 switch(_step){
   case 0:
     digitalWrite(Pin1, LOW);
     digitalWrite(Pin2, LOW);
     digitalWrite(Pin3, LOW);
     digitalWrite(Pin4, HIGH);
   case 1:
     digitalWrite(Pin3, HIGH);
   case 2:
     digitalWrite(Pin4, LOW);
   case 3:
     digitalWrite(Pin2, HIGH);
   case 4:
   case 5:
     digitalWrite(Pin1, HIGH);
     case 6:
   case 7:
   default:
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
 delay(2);
Learn to use millis(). Here is a great explanation of the Blink without Delay example.
Also, this would be an opportunity to learn about programming state machines. Machine states could be WAITING, CW, CCW, STOPPED.
Thank you SO MUCH. That article was a godsend, and was super easy for a beginner like me to understand. I've got it working perfectly now, and I'm super happy with it. Here's the final code btw:
int Pin1 = 10;
int Pin2 = 11;
int Pin3 = 12;
int Pin4 = 13;
int _step = 0;
int count=0;
unsigned long previousMillis = 0;
unsigned long interval = 4000;
 switch(_step){
   case 0:
   case 1:
   case 2:
   case 3:
   case 4:
   case 5:
     case 6:
   case 7:
   default:
 if (currentMillis - previousMillis > interval) {
    if (dir == false)
      dir = true;
      delay(99999999999999999999999999999999999);
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
 delay(2);
The delay(999999999999); part is the stopping thing, and while I know that it's not a great solution- it's a pretty simple one that works fine for this project.
To stop the Arduino from doing anything until it is turned off or reset, use this code...
while(true);
Your long row of nines will have an unpredictable result because that number won't fit in any regular integer type. The compiler will have to guess at what you want.
A better way to do it is to add a "wait" state to your state machine which can wait for a button press or some other event.
