hi i decided to make a line following robot with two sensors
so i wrote this code
#define m1p1 8
#define m1p2 9
#define m2p1 10
#define m2p2 11
#define sensor_right 0
#define sensor_left 1
#define led_right 6
#define led_left 5
int val_left = 0 ;
int val_right = 0 ;
pinMode(m1p1,OUTPUT);
pinMode(m1p2,OUTPUT);
pinMode(m2p1,OUTPUT);
pinMode(m2p2,OUTPUT);
pinMode(led_right,OUTPUT);
pinMode(led_left,OUTPUT);
val_left == analogRead(sensor_left);
val_right == analogRead(sensor_right);
if ((val_left)>(val_right))
digitalWrite(m1p1,HIGH);
digitalWrite(m1p2,LOW);
digitalWrite(m2p1,LOW);
digitalWrite(m2p2,LOW);
digitalWrite(led_right,HIGH);
digitalWrite(led_left,LOW);
else if ((val_right)>(val_left))
digitalWrite(m1p1,LOW);
digitalWrite(m2p1,HIGH);
digitalWrite(led_left,HIGH);
digitalWrite(led_right,LOW);
else if ((val_right)==(val_left))
i just wanted to test it so i didnt connect the motors but checked if the led's went on and off if i put a black tape under one of the sensors i expected one of the led to turn off but nothing happened
i checked the sensors on serial monitor if they were giving different values for white and black they give a value of 880 for white and around 600 for black
the sensors are led and ldr
