Help with fingerprint module SM 630
Hi
I am facing problem in getting finger print image using module SM 630, What I am trying to do is overcome the limitation of 768 finger Id's. In my case I need to save a finger print and then fetch the corresponding template received and will save it in database. But the problem is for even a single finger it is throwing different template every time, and before searching I will empty the database on device and will again add a finger and get the template and compare with the database.
Is it possible to eliminate the limitation of 768 finger id's? and What I ma trying to achieve is it possible?
Me too! First of all, is it possible to download the fingerprint to an SD card???
