help with float and int
Hi friends
I have a project that uses the arduino uno, a relay module, AD8495 K type amplifier and a lcd.
I worked for some time with lm35 sensor and it works fair....now I would replace it with AD8495 for use k type thermocouple.
My problem is during the calibration I use the 5 / 1023 and get the voltages, I take 3 points of temp and calculate the calibration rule and it gives a good R value, but after input the calib equation, the readings are very far from the real value.
Then I upload a simple program with INT function to read the A0 and after the same process I get about 1 degree of error.
I suspect the FLOAT function, but I use it to get more decimal places.
Please help me to correct this code seems the var "temp" and "tempPin" can be resumed to one
The original code is
#include <Wire.h>
#define I2C_ADDR    0x27 // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
//source: http://www.electroschematics.com/9540/arduino-fan-speed-controlled-temperature/
int row = 16; //  <<----- My LCD was 16x2
int column = 2; //  <<----- My LCD was 16x2
LiquidCrystal_I2C   lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin, BACKLIGHT_PIN, POSITIVE);
float tempPin = A0;   // the output pin of K thermocouple
float temp;
int led = 8;        // led pin
float templaw=5;   // the law ramp
    lcd.begin (row,column); // initialize lcd and turn on backlight
  lcd.home ();                   // go home
  pinMode(led, OUTPUT);
  pinMode(tempPin, INPUT);
   temp = readTemp();     // get the temperature
  if (temp < templaw - 1) {
   templaw = templaw + 0;
   templaw = templaw + 0.083;  //1seg em 1seg verifica
   if(temp > templaw) {        // if temp is higher than tempMax
     digitalWrite(led, LOW);  // turn on led
   } else {                    // else turn of led
     digitalWrite(led, HIGH);
   Serial.print("TEMP: ");
   Serial.println(temp, 4);      // display the temperature
   lcd.setCursor(1, 0);                                            // Set LCD cursor position (column, row)
   lcd.print("TEMP: ");                                             // Print text to LCD
   lcd.print (temp, 4);
   lcd.setCursor(1, 1);                                            // Set LCD cursor position (column,row)
   lcd.print("TEMPLAW: ");                                                     // Print text to LCD
   lcd.print (templaw);
   Serial.print("TEMPLAW: ");
   Serial.println(templaw);
float readTemp() {  // get the temperature and convert it to celsius
  temp = analogRead(tempPin);
  return (temp * (5.0 / 1023.0)) * 196.8 - 248.6;//calib dez2018
The simple analog read program is (i only use the A0)
   ReadAnalogVoltage
   Reads an analog input on pin 0 to 3, converts it to voltage,
   and prints the result to the serial monitor.cpalha 04dez2017
// the setup routine runs once when you press reset:
   // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
   // read the input on analog pin 0:
   int sensorValue0 = analogRead(A0);
    int sensorValue1 = analogRead(A1);
     int sensorValue2 = analogRead(A2);
      int sensorValue3 = analogRead(A3);
   // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
   float voltage0 = sensorValue0 * (5.0 / 1023.0) * 192.2 - 251.42;//calib ago2018
  float voltage1 = sensorValue1 * (5.0 / 1023.0);
 float voltage2 = sensorValue2 * (5.0 / 1023.0);
float voltage3 = sensorValue3 * (5.0 / 1023.0);
   // print out the value you read:
 Serial.print(voltage0, 1);
 Serial.print(" ");
  Serial.print(voltage1, 4);
   Serial.print(" ");
   Serial.print(voltage2, 4);
    Serial.print(" ");
   Serial.println(voltage3, 4);
   delay(10000);
float tempPin = A0;  // the output pin of K thermocoupleWhy is this pin number a float ?
UKHeliBob:
. Because it isn't connected to anything? :smiley:
The pin number is the Analog 0
It is connected because I have readings
for example
With my this code:
54.81c --- 1.5640volt
17.21------1.3685volt
6.01c----1.3099volt
With other code (INT function)
41.71c----1.4761v
18.21c----1.3539v
6.91c----1.3001v
best
cpalha
No, the pin number should not be a float.
It should be an integer, preferably of type byte or uint8_t
AWOL:
of type 'const byte' or 'const uint8_t'
Pins don't typically change :slight_smile:
So I need to replace the FLOAT for INT?
And in the code (as I am a begginner in arduino) seems the "temp" and "tempPin" could be the same, for example always "temp"
cpalha:
better replace float for 'const byte' in declaring pins , you could save much SRAM for that
Like that
float tempPin = A0;
replace for
const byte tempPin = A0;
Hi
Why the setup for analog read could not be as the simple program to read Analog out??
float temp;
int tempPin = 0;
temp = temp * 0.48828125;
Serial.print("TEMPRATURE = ");
Serial.print(temp);
Serial.print("*C");
It's your program. Make it as simple or as complicated as you want
According to the datasheet, the AD8495 outputs 5mV per °C, so:
tempC = analogRead(A0) / 1.023;
Serial.println(tempC);
Should work.
UKHeliBob:
Hi friend if I had knowldge to do that I was not here to ask for help. This program results from other examples that I found. and worked for years with LM35, now I need to improove it with thermocouple.
thanks
cpalha
I am having a mighty hard time following your descriptions of what you're seeing.
Make sure you're not getting integer-division'ed.
10/3 = 3 (integer)
10.0/3 = 3.33 (float, type of second operand is promoted according to C type promotion rules)
10/3.0 = 3.33
float x = 10/3; //x is still 3, because it didn't get turned into a float until you stored the result.
also:
int x = 9.99; //x is 9. Converting floats to int truncates, not rounds.
Well, I don't understand your "calibration", but since the AD8495 outputs half the mV per degree as the LM35, try multiplying the ADC result by 2 in your original program.
  temp = analogRead(tempPin) * 2; //<<<<<<<<
If that doesn't work, you may have the thermocouple connected backward, try reversing the wires.
I only need to get the reading for the A0 with about 2 decimal places...
cpalha:
That's too bad that analogRead returns an integer.
AWOL:
Can you please explain better??? Do you mean an integer without decimal places??? I need precision, because I will work with temperatures from 0ºc to 100ºC. And the changes are in milivolts...
Is there any other kind ?
You could get about 5 times better resolution using the Arduino's 1.1V internal reference, but would limit your maximum temp to about 220°C. See what kind of results you get with this test sketch.
// thermometer, no floats, no delays
const byte sampleBin = 8, // number of samples for smoothing
           aInPin = A0;
const int calValue = 0; // adjust for calibration
const int kAref = 1100, // analog ref voltage * 1000
                        // measured with accurate DMM
          kSampleBin = sampleBin * 1000,
          tEnd = 5000; // update time in mS
int tempC,
    tempF;
uint32_t total,  // sum of samples
         tStart; // timer start
  analogReference(INTERNAL); // use 1.1V internal ref
  analogRead(aInPin);
  total = analogRead(aInPin) * sampleBin;
  if(millis() - tStart > tEnd)
    tStart = millis(); // reset timer
    total -= (total / sampleBin); // make room for new reading
    total += analogRead(aInPin); // add new reading
    tempC = total * kAref / kSampleBin * 2 + calValue;
    tempF = (tempC * 18 + 3200) / 10;
    Serial.print(analogRead(aInPin));
    Serial.print("\t");
    Serial.print(total); // sum of samples
    Serial.print("\t");
    prntTemp(tempC);
    prntTemp(tempF);
void prntTemp(int temp){
  Serial.print(temp / 10); // whole degrees
  Serial.print(".");
  Serial.print(temp % 10); // tenths
  Serial.print("\t");
