help with ftoa function
hiii every buddy ... im only trying to get afloat number whom im sending with xbee ... i need this number for math matical analysis after that /// so far im able to get the number into char array after that im using the ftoa func. so i can work with the number ... but im not using this func. probaply it returns 0 all the time ... so if any one can tell me what is the right thing to do here is my code :
#include <stdlib.h>
String readString;
while (Serial.available()) {
delay(10);
char c = Serial.read(); //gets one byte from serial buffer
readString += c;} //makes the string readString
if (readString.length() >0) {
Serial.println(readString);
double n=0;
char carray[6];
readString.toCharArray(carray, sizeof(carray));
ftoa(carray,n,2);
Serial.println(carray);
readString="";
char *ftoa(char *a, double f, int precision)
long p[] = {0,10,100,1000,10000,100000,1000000,10000000,100000000};
char *ret = a;
long heiltal = (long)f;
itoa(heiltal, a, 10);
while (*a != '\0') a++;
*a++ = '.';
long desimal = abs((long)((f - heiltal) * p[precision]));
itoa(desimal, a, 10);
Serial.println(ret);
return ret;
ftoa is float to ascii. You have an ascii string that you want to create a float from. So, you want a atof() function (ascii to float). Fortunately, one already exists. Just use it.
it works good thanks alotttt/// i have another question ... if im sending 2 numbers and iwant to save them in defferent variables what technic do u recomend ?? send a end of packet marker between them or i need to focus in the receiver side ???
Whatever the sender does, the receiver has to undo. So, if you send a string like "<123,456>" that has start (<) and end (>) markers, you still need to make the receiver parse the resulting relevant data (123,456) using strtok(), most likely.
