Hello, I am new to programming and I am currently writing a code for a midi controller which I would like to make as reusable as possible.
I have started by writing a code for my mode selectors. Basically pushbuttons which can be configured to trigger 2 or 3 modes each, each connected to its own led which is off, on or blinking.
I wrote the code using arrays and the code appears to be working ok. Now I would like to make a function of this code so that I can reuse this in future and make the code a bit cleaner. However I am getting all sort of errors. I presume it should be a return function as it needs to return the modes type and values (i;e mode A1, A2 or A3; B1 B2 or B3, etc. but after viewing many tutorials I am still not getting there. I am clearly missing something. I have attached my working code.
Any help would be really appreciated please.
Thanks.
Thank you both.
I am going to have a look at this thread and hopefully I will clarify the matter. In the meantime I have done what Delta G suggested. formatted the code better. I am going to post it now Hopefully in the right way.
I have been able to compile the function properly if I make it a void function but when I test it I gets weird result this is what happen when I run the 3 tests I have made (which you can see commented in the code):
if I run test 2 (which is inside the function itself) the code runs perfectly - but when I RUN test 2 (in void loop) I only get MODE 2 - TYPE 0; no matter what button I press.
Even more strangely when I uncomment test 3 i get an error message ('modeselection' was not declared in this scope) and I cannot compile. I find this quite weird.
const int modeType = 2; // * how many modes types (buttons and pins)
const int modesNumber[modeType] = {3, 2}; // * how many modes for each type
const int modeLedPin[modeType] = {12, 13}; // * which led pins are used
const int modeButton[modeType] = {2, 4}; // * which button pins are used
int modeLedState[modeType] = {0}; // ledState used to set the LED - only for mode selection with led blink indicator
int modeButtonState[modeType]; // current state of the Mode Button
int modeButtonPState[modeType] = {1}; // previous state of the Mode Button,initialise it to HIGH
int mode[modeType] = {1, 1}; // define mode variable and initialise it to 1
int i;
// blinking timing
unsigned long previousMillis [modeType] = {0}; // will store last time LED was updated - only for mode selection with led blink indicator
const long interval = 500; // interval at which to blink (milliseconds) - only for mode selection with led blink indicator
// DEBOUNCE VARIABLE
unsigned long lastDebounceTimeMB[modeType] = {0}; // the last time the mode button button was pressed
unsigned long debounceDelay = 20; // the debounce time; increase if the output flickers
for (i = 0; i < modeType; i++) {
pinMode(modeLedPin[i], OUTPUT); // set the digital pin for led as output
pinMode(modeButton[i], INPUT_PULLUP); // set the digital pin for ModeButtoSerial.begin (9600);begin (9600);
modeSelection();
// TEST 2
// Serial.print("MODE "); // Print MODE TYPE AND MODE NUMBER
// Serial.print(i); // Print MODE TYPE AND MODE NUMBER
// Serial.print(" TYPE "); // Print MODE TYPE AND MODE NUMBER
// Serial.println(mode[i]); // Print MODE TYPE AND MODE NUMBER
// TEST 3
// if ((i == 0)&&(mode[i]) == 1){Serial.print("MODE A1");
// if ((i == 0)&&(mode[i]) == 2){Serial.print("MODE A2");
// if ((i == 0)&&(mode[i]) == 3){Serial.print("MODE A3");
// if ((i == 1)&&(mode[i]) == 1){Serial.print("MODE B1");
// if ((i == 1)&&(mode[i]) == 2){Serial.print("MODE B2");
// if ((i == 1)&&(mode[i]) == 3){Serial.print("MODE B3");
void modeSelection() {
modeButtonState[i] = digitalRead(modeButton[i]); // check state of mode button and what happen when mode button is pressed
if ((millis() - lastDebounceTimeMB[i]) > debounceDelay) // DEBOUNCE FUNCTION FOR MODE BUTTON
{ if (modeButtonState[i] != modeButtonPState[i]) // check that button state is different from previous button state
{ lastDebounceTimeMB[i] = millis(); // update debounce time
if (modeButtonState[i] == LOW) // if button is pressed increase mode
{ mode[i] ++;
if (mode[i] > modesNumber[i]) // if mode bigger than number of modes available
mode[i] = 1; // bring back mode to initial value
//TEST 1
modeButtonPState[i] = modeButtonState[i]; // update mode button state
switch (mode[i]) {
case 1: // SWITCH LED OFF
digitalWrite(modeLedPin[i], LOW);
case 2: // SWITCH LED ON
digitalWrite(modeLedPin[i], HIGH);
case 3: // LED BLINKING
{ unsigned long currentMillis = millis();
if (currentMillis - previousMillis[i] >= interval) // check that intervall has passed
{ previousMillis[i] = currentMillis; // save the last time you blinked the LED
if (modeLedState[i] == LOW) {
modeLedState[i] = HIGH;
else {
modeLedState[i] = LOW;
digitalWrite(modeLedPin[i], modeLedState[i]); // set the LED with the ledState of the variable:
fluxia:
There is nothing strange about that. You don't have matched braces {}
If you write your code with one statement on each line that sort of problem is more obvious. Rather than
do it like this
if ((i == 0)&&(mode[i]) == 1) {
} // in the one line version this brace is missing
Thank you Robin, I have read your Planning and Implementing an Arduino Program and I like the way you organise your coding and the style of your command.
I have corrected the syntax silly mistake but I am still having problems in outputting the modes selected - it's probably taking me longer as I wanted to use arrays, and I am still familiarising with things tomorrow I will give it another shot and try to find where I am going wrong.
There were quite a few problems in the code. I reviewed all the variables and created two functions, one for mode selection and one for printing (to test it out).
It seems to be running smoothly.
I will attach the final file for who people who may find it useful.
It's basically to create buttons to select mode functions (I will use it for a midi controller).
It can have as many buttons as you like and 2 or 3 modes to be selected for each button (the correspondent led will indicate the mode: off for mode 1, on for mode 2 and blinking for mode 3).
Thanks for the advice !
Cheers
A
const int numberOfTypes = 2; // * how many modes types (buttons and pins)
const int numberOfModes[numberOfTypes] = {3, 2}; // * how many modes for each type
char typeLetter[] = "AB"; // * letters assigned to mode types
const int modeLedPin[numberOfTypes] = {11, 12}; // * which led pins are used
const int modeButton[numberOfTypes] = {2, 4}; // * which button pins are used
int modeLedState[numberOfTypes] = {0}; // ledState used to set the LED - only for mode selection with led blink indicator
int modeButtonState[numberOfTypes]; // current state of the Mode Button
int modeButtonPState[numberOfTypes] = {1}; // previous state of the Mode Button,initialise it to HIGH
int modeNumb[numberOfTypes] = {1, 1}; // define mode-numbers variable and initialise it to mode number "1" for all types
// BLINKING TIMING================================================
unsigned long previousMillis [numberOfTypes] = {0}; // will store last time LED was updated - only for mode selection with led blink indicator
unsigned long lastPrint = 0;
// DEBOUNCE VARIABLE==============================================
unsigned long lastDebounceTimeMB[numberOfTypes] = {0}; // the last time the mode button button was pressed
// SETUP =========================================================
for (int i = 0; i < numberOfTypes; i++) {
Serial.print("MODE TYPE: ");
Serial.print(typeLetter[i]);
Serial.print(" MODE NUMBER: ");
Serial.println(modeNumb[i]);
modeSelection();
printFunction();
int i;
for (i = 0; i < numberOfTypes; i++) {
modeButtonState[i] = digitalRead(modeButton[i]); // read the state of mode button
if ((currentMillis - lastDebounceTimeMB[i]) > debounceDelay) { // DEBOUNCE FUNCTION FOR MODE BUTTON
if (modeButtonState[i] != modeButtonPState[i]) { // check that button state is different from its previous state
lastDebounceTimeMB[i] = currentMillis; // update debounce time
if (modeButtonState[i] == LOW) { // if button is pressed
modeNumb[i] ++; //increase mode number for that mode type
if (modeNumb[i] > numberOfModes[i]) { // if number bigger than number of modes available
modeNumb[i] = 1; // bring back mode number to initial value
switch (modeNumb[i]) {
case 3: { // LED BLINKING
if (currentMillis - previousMillis[i] >= interval) { // check that intervall has passed
else {
void printFunction() {
unsigned long currentTime = millis();
if ((currentTime - lastPrint) > 2000) {
lastPrint = currentTime;
