Help with Gemma project
Trying to get this project to work :Audio-Reactive Mask | LED Masquerade Masks | Adafruit Learning System
I am brand new to using Arduino and Gemma.
I have copied the code to sketch. Verified. Then tried to upload it. I keep getting an error message.
This is the information I copied from the Arduino software:
Arduino: 1.8.3 Hourly Build 2017/05/23 05:12 (Mac OS X), Board: "Arduino Gemma"
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c: In function 'attachInterrupt':
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:166:8: warning: #warning attachInterrupt may need some more work for this cpu (case 1) [-Wcpp]
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c: In function 'detachInterrupt':
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:255:8: warning: #warning detachInterrupt may need some more work for this cpu (case 1) [-Wcpp]
In file included from /private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:29:0:
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c: In function 'INT1_vect':
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:310:15: warning: 'INT1_vect' appears to be a misspelled signal handler, missing __vector prefix [-Wmisspelled-isr]
IMPLEMENT_ISR(INT1_vect, EXTERNAL_INT_1)
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/WInterrupts.c:310:1: note: in expansion of macro 'IMPLEMENT_ISR'
In file included from /private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Tone.cpp:37:0:
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Tone.cpp: In function 'void TIMER2_COMPA_vect()':
/private/var/folders/pr/3yql3q2n32q62xndptyfkvk40000gn/T/AppTranslocation/987638B6-51B3-4400-9A47-C6C62EB1298F/d/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Tone.cpp:538:5: warning: 'TIMER2_COMPA_vect' appears to be a misspelled signal handler, missing __vector prefix [-Wmisspelled-isr]
ISR(TIMER2_COMPA_vect)
Sketch uses 1224 bytes (23%) of program storage space. Maximum is 5310 bytes.
Global variables use 11 bytes of dynamic memory.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Please help, clearly I have no idea what I'm doing.
Please do this:
  • Tools > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the process fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
There is a special procedure you have to follow to upload to a Gemma. It is described here:
