Help with gerber files needed by PCB manufacturers
I'm learing how to design PCBs with Eagle.
More or less now I begin to understand Eagle and can create PCBs, new libraries etc.
I've done a home-made single layer PCB and as a next step I would like to order a slightly more complex circuit (with the free Eagle version, two layers).
I have the book "Build your own PCB" by Al Williams and there are some guidelines to prepare Gerber files (.cmp, .sol, .plc...). However, I also downloaded the SparkFun CAM file and it generates a totally different set of filename extensions. So right now I'm really confused !
My questions are:
1-Is there a set of standard gerber files ?
2-How do you review and verify your files before submitting them ?
3-Is someone out there accepting Eagle files ? (In case this makes sense)
If someone who has ordered PCBs could help me I would really appreciate it.
Thanks,
No...yes...kind of. It's common for Eagle users to generate:
.cmp: top-side copper ("component" side, hence cmp)
.sol: bottom-side copper ('solder" side, hence sol)
.plc: top-side silkscreen (PLacement on Component side)
.pls: bottom-side silkscreen (PLacement on Solder side)
etc.
But there is no standard for what the files are called. Just be clear about it when you submit your files.
Use a Gerber file viewer like GC-Prevue, ViewMate, or gerbv for Linux/Mac systems.
Yes...but don't do it. You are counting on someone else interpreting your board and generating what they think is the CAM data. Proceed as you suggest above: learn to generate the CAM data, verify it (twice) using a Gerber viewer, then submit that. You will have much fewer surprises.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Yes. Laen at dorkbot will accept eagle files. You'll have to make sure your silkscreen info is correct, but that's the only catch I had. I've sent in 4 breakout board designs, all came out great.
-j
dorkbop pdx is pretty good. I once contacted someone else and they told me they only accept protel 99 file. Darn the cheap price comes from not upgrading I guess.
