Hello, please accept my apologies in advance, I am a total noob and may not be in the right place. Anyways I have been tinkering with an Uno v3 board, and LPD8806 rgb strip of 20 led's. I have been able to get many examples to run perfectly and from that I have taken parts of the code and been able to successfully change colors, timing etc. But I am now trying to duplicate a sketch found at: http://interface.khm.de/index.php/lab-log/digital-addressable-led-strip-arduino/
The led strip used there is different, but it states that the sketch is based off of the LPD8806 library. I have been all over searching adafruit, forums, google, youtube, even sent a message to to Martin Nawrath (Creator of that code). Still cannot get the sketch to run and be controlled with a potentiometer. I have 2 that I have been trying, a slider and a regular pot. I know they both work because I have been able to get a sketch working where the flashing led speed is controlled by pot. Can anyone shed some light into what it is I'm missing? I'm specifically trying to get the "lightbarpot" function to work. Its the first video towards the bottom of the page. Here's the sketch provided:
/* Digital RGB LED Stripe testprogram
/* for Stripe Type Art Nr: EKXMAGICXSTRIPIP45
* Lab3 12/2011 Nawrath
* Kunsthochschule fuer Medien Koeln
* Academy of Media Arts Cologne
* http://interface.khm.de
thanks to adafruit, ideas have be taken from the
Arduino library for the LPD8806-based strip.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see .
int datapin = 2; // Led Strip St Pin
int clockpin = 3; // Led Strip Ci Pin
int pinLed=13; // Arduino Led Pin 13
#define nled 49 // total number of controlled leds
unsigned int rgbPixel[nled]; // rgb values of whole led strip
unsigned int cc; // color
int r,g,b;
Serial.println("DIGITAL LED STRIP TEST");
pinMode(clockpin,OUTPUT);
pinMode(datapin,OUTPUT);
pinMode(pinLed,OUTPUT);
r = random(31);
g = random(31);
b = random(31);
// uncomment function :
colorChase(wheel(random(96)),50) ;
// randomFlash(50);
// rainbowWheel(100,2);
// test();
// lightBarPot();
digitalWrite(pinLed,!digitalRead(pinLed)); // blink arduino led pin 13
// send color values from pixel array to led strip
void show() {
unsigned int ii,b1;
for (ii=0; ii < nled; ii++ ) {
bitWrite(PORTD,datapin,HIGH);
bitWrite(PORTD,clockpin, HIGH);
bitWrite(PORTD,clockpin, LOW);
for ( b1=0x4000; b1; b1 >>= 1) {
if(rgbPixel[ii] & b1) bitWrite(PORTD,datapin, HIGH);
else bitWrite(PORTD,datapin, LOW);
latchLeds(nled);
// activate new color pattern in ledstrip
void latchLeds(int n) {
for(int i = 8 * n; i>0; i--) {
// set color value as rgb argument , values = 0..31
unsigned int color(int r, int g, int b) {
// color are 3 groups of 5 bit (0..31)
r=r & 0x1F;
g=g & 0x1F;
b=b & 0x1F;
return (b << 10) | (r << 5) | g;
void colorChase(unsigned int c, int wait) {
int i;
for (i=0; i < nled; i++) {
rgbPixel[i]= c;
if (i == 0) {
rgbPixel[nled-1]= 0;
else {
rgbPixel[i-1]= 0;
show();
delay(wait);
void rainbowWheel(int wait,int wave) {
static int si;
int ii;
for (int i=0; i < nled; i++) {
ii=i+si;
if (ii > 95 ) ii=ii-96;
rgbPixel[i]=wheel(ii);
si=si+wave;
if (si > 95 ) si=0;
show();
delay(wait);
void randomFlash(int wait) {
for (int i=0; i < nled; i++) rgbPixel[i]=0x0;
r = random(31);
g = random(31);
b = random(31);
rgbPixel[random(nled)]= color(r,g,b);
show();
delay(wait);
// colorwheel with 96 colors, 0..95
unsigned int wheel(int WheelPos)
byte r, g, b;
switch(WheelPos / 32)
case 0:
r = 31 - WheelPos % 32; //Red down
g = WheelPos % 32; // Green up
b = 0; //blue off
case 1:
g = 31 - WheelPos % 32; //green down
b = WheelPos % 32; //blue up
r = 0; //red off
case 2:
b = 31 - WheelPos % 32; //blue down
r = WheelPos % 32; //red up
g = 0; //green off
return(color(r,g,b));
void test() {
int aa;
pinMode(14,OUTPUT); // connect a potentiometer with input,wiper,output to
pinMode(16,OUTPUT); // analog pins A1,A2,A3
digitalWrite(16,1); //
aa= analogRead(15)/32;
rgbPixel[0]=color(aa,0,0);
rgbPixel[1]=color(0,aa,0);
rgbPixel[2]=color(0,0,aa);
show();
delay(100);
// light bar controlled by analog pin 1 ( potentiometer )
void lightBarPot() {
int aa;
pinMode(16,OUTPUT); // analog pins A1 pot+,A2 pot-wiper,A3 pot-
aa= analogRead(15);
Serial.println(aa);
aa= (500-aa);
aa=aa/5;
aa=aa+25;
rgbPixel[i]=0x0;
if (i < aa) rgbPixel[i]=color(31,31,31);
show();
delay(5);
Thank you for your time.
