Help with getting RFID, SD card and audio to work together
Hi
I am a front end developer but I am quite new to the micro controller world.
The Project
I am trying to create a RFID tag controlled mp3 player for my son (kind of like a "tonieBox" clone.
The idea is to build something like this:
  • When we put an RFID tag on the device, we must read the tag and start playing mp3 from the corresponding folder on the sd card
  • When we remove the RFID we should stop playing
The parts
  • I have started out with an Arduino Uno, but now changed to a ESP32 doit devkit v1 (because of the builtin wifi)
  • RFID reader: RFID-RC522
  • SD card reader: micro sd card adapter (nothing else written. SD, SCK, MOSI, MISO, VCC, GND pins)
  • Audio: MAX98357A
What i have done
I have been following some tutorials and tackling the problem piece by piece.
  • I have the RFID tag reader working
  • I have buttons for start, stop, volume up and down working
  • I have connected the SD card and could read the content of a test txt file
My problem
I now need to play the correct m3 file when a tag is present.
I thought this would be something easy, but after trying for a week i am about to give up. i have no idea what i am doing wrong.
I get no sound!
If i add a Serial.println to the code where i read the tag, i see it on the Serial Monitor, but i can't get the audio to work!
The code
I'm not sure what code to post.
I have split the code into several smaller files, you can see it all on the github page for the project
I would really thankful for any help.
Please let me know if there is any other information you need.
Thank you!
Do you have a sample program for JUST the mp3 player and does it work? You need to test the hardware set up.
Posting the part where the problem appeared, the SD card being execised, would be good.
Does using Serial.println of the filename of the mp3 file tell anything?
Having a number of predefined files used according to the selection ought to be easy.
Following the advice from both of you i have tried a couple of different things to see if it works just the mp3 player.
The first thing i did was to use a different speaker. No change... :frowning:
Then i tried adding some serial prints to the see if the audioPlayer is getting initialized:
Added this:
Serial.println("AFTER SETUP ========================");
  Serial.println(audioPlayer.isRunning());
  Serial.println(audioPlayer.getVolume());
  Serial.println(audioPlayer.getBitsPerSample());
  Serial.println(audioPlayer.getFileSize());
  audioPlayer.connecttoSD("/amaze.mp3", 0);
  Serial.println("AFTER CONNECT ========================");
and get:
0
15
16
0
1
15
16
3980786
3.980.786 is indeed the number of bytes on the file (as i see it on my mac).
So i think the audio player is getting initialized and it can get the mp3 file from the SD card. Am i wrong assuming this?
So i think the problem is with the MAX89357A module or with how i have it wired.
I have another module around. just need to solder some pins so i can try it (will do tomorrow).
I have tried connecting to different pins, but no luck either.
I have some problem understanding what the ESP32 pins are for. It's not like just analog or digital pins like on my UNO. The pins have some "roles", so maybe i am connecting to some wrong pins?
Currently:
  • LRC: pin 26
  • BCLK: pin 12 (also tried on 22)
  • DIN: pin 25
    Could this be the problem?
Any other ideas on how i could debug this?
Would it be possible to connect a speaker directly to the board?
Certainly, but will be the same as a short circuit. Will kill your Arduino.
Please post the entire code. The mistake is for sure not in the snippet You posted.
@Railroader The code is split into smaller files, so i am not sure how to post that correctly.
On the question i have posted a link to the github, is that ok? enough?
Here it is again: the github for the project where you can see all the code
thank you
I have just tried a new MAX98357A. Still no sound.
Not sure how to debug this any further. Any ideas?
I have added the following auxiliar functions from the ESP32-audioI2S library:
void audio_info(const char *info){
    Serial.print("info        "); Serial.println(info);
void audio_id3data(const char *info){  //id3 metadata
    Serial.print("id3data     ");Serial.println(info);
void audio_eof_mp3(const char *info){  //end of file
    Serial.print("eof_mp3     ");Serial.println(info);
void audio_showstation(const char *info){
    Serial.print("station     ");Serial.println(info);
void audio_showstreaminfo(const char *info){
    Serial.print("streaminfo  ");Serial.println(info);
void audio_showstreamtitle(const char *info){
    Serial.print("streamtitle ");Serial.println(info);
void audio_bitrate(const char *info){
    Serial.print("bitrate     ");Serial.println(info);
void audio_commercial(const char *info){  //duration in sec
    Serial.print("commercial  ");Serial.println(info);
void audio_icyurl(const char *info){  //homepage
    Serial.print("icyurl      ");Serial.println(info);
void audio_lasthost(const char *info){  //stream URL played
    Serial.print("lasthost    ");Serial.println(info);
void audio_eof_speech(const char *info){
    Serial.print("eof_speech  ");Serial.println(info);
an now the serial output looks like this:
Setting up audio player...
0
21
16
0
info        PSRAM not found, inputBufferSize: 6399 bytes
info        buffers freed, free Heap: 149252 bytes
info        Reading file: "/amaze.mp3"
info        MP3Decoder has been initialized, free Heap: 121536 bytes
1
21
16
3980786
info        Closing audio file
info        End of file "amaze.mp3"
eof_mp3     amaze.mp3
So it opens the file but it immediately closes it!
Any ideas?!
I am still struggling with this problem, and i have really no idea what is going on.
I have added another help function to my code:
    Serial.print("audio_info: "); Serial.println(info);
    if(strcmp(info, "stream ready") == 0){
        Serial.printf("FileSize is %i bytes\n", audioPlayer.getFileSize());
The Serial Output now looks like this:
0
21
16
0
audio_info: PSRAM not found, inputBufferSize: 6399 bytes
audio_info: buffers freed, free Heap: 149260 bytes
audio_info: Reading file: "/amaze.mp3"
audio_info: MP3Decoder has been initialized, free Heap: 121544 bytes
1111111111
2
0
1
21
16
3980786
audio_info: Content-Length: 3980786
audio_info: ID3 framesSize: 144
audio_info: ID3 version: 2.4
audio_info: ID3 normal frames
id3data     UserDefinedText: major_brandisom
id3data     UserDefinedText: minor_version512
id3data     UserDefinedText: compatible_brandsisomiso2mp41
id3data     SettingsForEncoding: Lavf58.45.100
audio_info: Audio-Length: 3980642
audio_info: stream ready
FileSize is 3980786 bytes
audio_info: syncword found at pos 0
audio_info: Channels: 2
audio_info: SampleRate: 44100
audio_info: BitsPerSample: 16
audio_info: BitRate: 128000
I am really lost here. If some one could help me debug this problem i would be really grateful!
