Hello,
I am programming a real time clock (using Arduino Uno, DS1307, LCD 16x2)
Have done the following:
- LCD shows 2 rows - upper row is YY/MM/DD, lower row is hh/mm/ss GMT-0
- 24 hour format
- Three additional buttons - one cycles through upper and lower row values, second one increases the value of the active selection and the third one decreases the value of the active selection.
All I need right now is to make two more buttons that change the GMT offset from min to max value. Additionally, year, month, day and hour must change according to the offset and the default value is GMT-0.
//************Libraries**************//
#include <Wire.h>
#include <RTClib.h>
LiquidCrystal_I2C lcd(0x20,16,2); // 0x3f if real, 0x20 if simulation environment
RTC_DS1307 RTC;
//************Buttons*****************//
int P1=6; // Set menu
int P2=7; // Set menu +
int P3=8; // Set menu -
int P4=4; // GMT offset -
int P5=5; // GMT offset +
//************Variables**************//
int hourup;
int minup;
int yearup;
int monthup;
int dayup;
int menu=0;
lcd.begin(); // starts LCD
lcd.backlight(); // activates the backlight of the LCD
lcd.clear(); // clears LCD
Serial.begin(9600); // start the serial connection to the PC.
pinMode(P1,INPUT); // setting pin1 as input
pinMode(P2,INPUT); // setting pin2 as input
pinMode(P3,INPUT); // setting pin3 as input
pinMode(P4,INPUT); // setting pin4 as input
pinMode(P5,INPUT); // setting pin5 as input
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// Set the date and time at compile time
// RTC.adjust(DateTime(__DATE__, __TIME__));
// The default display shows the date and time
RTC.adjust(DateTime(2019, 12, 10, 15, 49, 0));
//************Menu index increase if Set button is pressed**************//
if(digitalRead(P1))
menu=menu+1; // If P1 button is pressed, goes to the other menu
if (menu==0) // Main menu that shows date
DisplayDateTime(); // void DisplayDateTime()
if (menu==1) // Menu that allows to set the hour
DisplaySetHour(); // void DisplaySetHour()
if (menu==2) // Menu that allows to set the minute
DisplaySetMinute(); // void DisplaySetMinute()
if (menu==3) // Menu that allows to set the year
DisplaySetYear(); // void DisplaySetYear()
if (menu==4) // Menu that allows to set the month
DisplaySetMonth(); // void DisplaySetMonth()
if (menu==5) // Menu that allows to set the day
DisplaySetDay(); // void DisplaySetDay()
if (menu==6)
if (menu==7)
StoreAgg();
menu=0;
delay(100);
//************Displays current date and time**************//
void DisplayDateTime ()
DateTime now = RTC.now();
lcd.setCursor(0, 1); // sets cursor on the second line of the LCD
if (now.hour()<=9) // if the hour reaches more than 10, 0 will not be printed in front (01, 02, ... , 08, 09)
lcd.print("0");
lcd.print(now.hour(), DEC); // prints hours in decimals (DEC)
hourup=now.hour(); // sets variable to current hour that is set
lcd.print(":");
if (now.minute()<=9)
lcd.print("0");
lcd.print(now.minute(), DEC);
minup=now.minute();
lcd.print(":");
if (now.second()<=9)
lcd.print("0");
lcd.print(now.second(), DEC);
lcd.print(" GMT-0");
lcd.setCursor(0, 0);
if (now.year()<=9)
lcd.print("0");
lcd.print(now.year(), DEC);
yearup=now.year();
lcd.print("/");
if (now.month()<=9)
lcd.print("0");
lcd.print(now.month(), DEC);
monthup=now.month();
lcd.print("/");
if (now.day()<=9)
lcd.print("0");
lcd.print(now.day(), DEC);
dayup=now.day();
//************Setting hours**************//
lcd.clear();
if(digitalRead(P2)==HIGH) // if button 2 is pressed, do the following:
if(hourup==23) // so that overflow would not occur, if hours are more than 23, sets it back to 0 in the next line
hourup=0;
hourup++; // if no overflow is occuring, adds 1 to hours
if(digitalRead(P3)==HIGH)
if(hourup==0)
hourup=23;
hourup--;
lcd.setCursor(0,0);
lcd.print("Set hour:");
lcd.setCursor(0,1);
lcd.print(hourup,DEC);
delay(200);
//************Setting minutes**************//
lcd.clear();
if (minup==59)
minup=0;
minup++;
if (minup==0)
minup=59;
minup--;
lcd.setCursor(0,0);
lcd.print("Set minutes:");
lcd.setCursor(0,1);
lcd.print(minup,DEC);
delay(200);
//************Setting the year**************//
lcd.clear();
if (yearup==2099)
yearup=2000;
yearup++;
if (yearup==2000)
yearup=2099;
yearup--;
lcd.setCursor(0,0);
lcd.print("Set year:");
lcd.setCursor(0,1);
lcd.print(yearup,DEC);
delay(200);
//************Setting the month**************//
lcd.clear();
if (monthup==12)
monthup=1;
monthup++;
if (monthup==1)
monthup=12;
monthup--;
lcd.setCursor(0,0);
lcd.print("Set month:");
lcd.setCursor(0,1);
lcd.print(monthup,DEC);
delay(200);
//************Setting the day**************//
lcd.clear();
if (dayup==31)
dayup=1;
dayup++;
if (dayup==1)
dayup=31;
dayup--;
lcd.setCursor(0,0);
lcd.print("Set day:");
lcd.setCursor(0,1);
lcd.print(dayup,DEC);
delay(200);
//************Saving variables**************//
void StoreAgg()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("CURRENTLY SAVING");
lcd.setCursor(0,1);
lcd.print("PLEASE WAIT");
RTC.adjust(DateTime(yearup,monthup,dayup,hourup,minup,0));
lcd.clear();
Any help is appreciated.
