help with Green house code
I’m building a green house where the user can control or set the desired levels of various parameters.
the user interacts with the program via a 4x4 keypad.the program should display the status of the current values but when a key is pressed the user should be able to edit the values desired.
i know how the sensors works but the main problem is that the program is not detecting my keypresses.
code:
#include <LiquidCrystal.h> // include the library code
include <Password.h>
#include <Keypad.h>
const int numRows = 2;//constants for the number of rows and columns in the LCD
const int numCols = 16;
int count = 0;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);// initialize the library with the numbers of the interface pins
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = { {‘1’, ‘2’, ‘3’, ‘A’},
{‘4’, ‘5’, ‘6’, ‘B’},
{‘7’, ‘8’, ‘9’, ‘C’},
{’*’, ‘0’, ‘#’, ‘D’}
float humidity, temprature, moisture; // variables globally declared
boolean light;
byte rowPins[ROWS] = {22, 23, 24, 25}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {26, 27, 28, 29}; //connect to the column pinouts of the kpd
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
lcd.begin(numCols, numRows);
keypad.addEventListener(keypadEvent);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(“LOADING”);
for (int i = 0; i < 16; i++) {
lcd.setCursor(i, 1);
lcd.write(255);
delay(170);
lcd.clear();
{ // THE PROGRAM SHOULD DISPLAY THE STATUS OF SENSORS UNTILL A KEY IS PRESSED
keypad.getKey();
while (NO_KEY)//THIS DOES NOT WORK
lcd.print(“hello”);// EXAMPLE STATUS
void keypadEvent(KeypadEvent eKey)
{ switch (keypad.getState()) {
case PRESSED:
Serial.println(eKey);
delay(10);
switch (eKey)
// though i am able to get in this part
case ‘A’: lcd.clear(); // WANT USER TO ENTER A 4 DIGIT NUMBER WHICH CAN BE MADE AS SETPOINT OR UPDATES THE CURRENT VALUE
lcd.print(“Enter Desired”);
lcd.setCursor(0, 1);
lcd.print(“HUMIDITY:”);// THE USER SHOLD BE ABLE TO ENTER THE VALUE HERE WHICH WOULD BE UPDATED
case ‘B’: lcd.clear();
lcd.print(“TEMPRATURE:”);
case ‘C’: lcd.clear();
lcd.print(“MOISTURE:”);
case ‘D’: lcd.clear();
lcd.print(“LIGHT”);
lcd.print(“ON/OFF”); //BOOLEAN TRUE/FALSE
pease help
NEW_FILE.ino (2.36 KB)
  keypad.getKey();
    lcd.print("hello");// EXAMPLE STATUS
I am not familiar with the keypad library but should you not test the value returned by keypad.getKey();
you have to test it else your lcd would display some unknown characters. :)
vikram18: you have to test it else your lcd would display some unknown characters. :)
Where in your code are you testing the value returned by keypad.getKey() ? In any case, once the while loop is running how would the loop ever exit ?
vikram18:
you have to test it else your lcd would display some unknown characters. :slight_smile:
So why don’t you test it? The library page is very clear about it…
void loop(){
  char key = keypad.getKey();
  if (key != NO_KEY){
    Serial.println(key);
i,ve change the code.the key part works for now used waitForKey() :) to stop the execution untill user enters a key.
now i'm unable to convert the character entered to integer
code:
case 'D': lcd.clear(); lcd.setCursor(0, 0); lcd.print("LIGHT sett."); for (int i = 0; i < 4; i++) { char see = keypad.waitForKey(); if (see != NO_KEY && isdigit(see))
{ number=atoi(see);//error comes here number is declared globally as int
lcd.setCursor(i, 1); lcd.print(number);
Serial.println(number); arr*=number;*
  • delay(500);*
  • lcd.clear();*
  • break;* errors:
  • ^* exit status 1 invalid conversion from 'char' to 'const char*' [-fpermissive]
Post whole within code tags
#include <Keypad.h>
int number;
int arr[4];
char input[4]; //buffer for input characters
String totalarray = "";
{ {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
boolean light;
  lcd.clear();
  lcd.print("INITIALIZING");
    lcd.write(255);
    delay(100);
  lcd.clear();
{ lcd.setCursor(0, 0);
  lcd.print("Press key!");
  lcd.print("A::B::C::D::1");
  char selection = keypad.getKey();
  if (selection != NO_KEY)
    switch (selection)
          { number=atoi(see);
            arr[i]=number;
          }}}[code]
[/code]
i want to concatenate the 4 numbers entered so that they can be used to update the variable
If something is new, reading it back is a good idea ;)
And your indentation is a mess! See:
#include  // include the library code
#include
int number;
int arr[4];
boolean light;
  lcd.clear();
    lcd.write(255);
    delay(100);
  lcd.clear();
void loop(){
  if (selection != NO_KEY){
    switch (selection){
      case 'D':
        lcd.clear();
        for (int i = 0; i < 4; i++){
          if (see != NO_KEY && isdigit(see)){
            number=atoi(see);
            arr[i]=number;
Wayyyy more readable. I prefer to put the { on the same line as the if/else/for/etc but putting it on a new line is fine as well. But then it should be the only thing on that line, so not:
          { number=atoi(see);
Together with
Makes very hard to read code.
But back tot he problem.
First of all, you never try to combine all the keys... See is just 1 char. And atoi expects a string. But I would do something like:
    switch (selection){
      case 'D':
        lcd.clear();
        number = 0;
            number *= 10;
            number += see - '0';
