Help with GSM shield!!
Hello everyone
I´m using these shield: https://docs.google.com/file/d/0B7YYTsMTTwiLSTBiSmUzQ0IxdVk/edit?usp=sharing&pli=1
the SIM900 shield and using this code to send messages,as I write the messages on the serial monitor, and to turn off calls, as I type 'R' on the serial monitor :
  Software serial multple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 created back in the mists of time
 modified 25 May 2012
 by Tom Igoe
 based on Mikal Hart's example
 This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(5, 6); // RX, TX pins selected by the jumpers of the shield
char state=0;
int c=0;
uint8_t string_a_ser_env[128];
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  while(Serial.available() >0)
    string_a_ser_env[c] = Serial.read();
    c++;
    state=1;
    Serial.write("FINISHED READING \n");
    delay(10);
  if (state==1 && string_a_ser_env[0] != 82)
   //Serial.write("STADO 2 \n");
   state=2;
 if (state==1 && string_a_ser_env[0] == 82)   //cancels the call when reads 'R'
   mySerial.println("ATH");
  state = 0;
  c=0;
  if (state == 2)
      //Serial.write(string_a_ser_env,c);
      mySerial.write("AT+CMGS=\"+*************\"\r");
      mySerial.write(string_a_ser_env,c);
      mySerial.write(0x1A);
      state=0;
      c=0;
      Serial.write("SENT A SMS\n");
So, what I need now is to identify a signal when I´m receiving a call(like to read something on the serial port, or any code that the shield sends to me) and to get the phone number that is calling me. Does anyone has any idea of how to do it?
Thanks
