Also, SCL and SDA of the sensor pulled up to 3V3, both with 3.3KOhm resistors.
Arduino I2C scanner from playground (I2cScanner) found the sensor (I've tested it with
Wire.begin();
Wire.setClock(400000); // use 400 kHz I2C
too ), here is output of scanner:
Scanning...
I2C device found at address 0x2A !
done
Also I want to mention, that I tried to use another one similar sensor now (I bought 5 sensor boards from one seller at one time). I thought, maybe one board is not functioning properly, but another one GY-53-L1X board is not working with those libraries too.
Maybe all 5 boards are not working properly, I don't know...
Welcome to the forum.
Was the spam filter a little rough on you ?
You can still edit your post (but don't change it too much).
For example
VCC - 3V3
GND - GND
and so on.
A "datasheet" on a Google Drive might be suspicious.
The Pololu .init() function does some testing and assumes that it runs at a certain voltage.
Can you show a photo of your module and reverse engineer it and make a schematic of it ?
If you want something that works, then you should buy something from a reliable seller.
Adafruit has it: https://www.adafruit.com/product/3967. They test everything before they sell it, they provide a schematic, they make a tutorial, they make a library, they have a forum, and so on.
Most important is that if the chip needs to run at 2.8V, they actually let the chip run at 2.8V and they tell if their module is compatible with 3.3V and 5V boards (they made it compatible with 3.3V and 5V boards).
Your module is totally :poop: because it has no schematic and no one knows if it actually works. It might do some trick for the I2C bus that is not according to the datasheet.
[UPDATE]
I read now that it as a STM32 processor. Is the I2C bus connected to the sensor chip and STM32 as well ? What is the STM32 doing ?
Thanks for the photos. It is a module with 10k resistors, but it does not have a level shifter to convert your 3.3V I2C bus to a 2.8V I2C bus for the sensor.
It does not look good. Here and here are troubles with that module on this forum. It seems that there was no solution.
Do you solder the pins ? Some forget that.
The I2C interface might never work. The examples that I see with an Arduino board use the PWM signal. I suggest to try the Serial interface or else the PWM signal.
Your module might stop working after some time, because I'm sure that the SDA and SCL go directly to the 2.8V sensor chip. That module is not okay.
