Help with Hall Effect Sensor Interrupts - Causes program to get stuck
I've used the following code to read from a hall effect sensor. It works perfectly fine on its own but when I tried to integrate it into my main project, when the function flow_sensor() is called in void loop, the program gets stuck there. I believe it might have to do with the interrupts or delay(1000). I've tried different things with no luck. Hopefully it's an easy fix for any of you and I would really appreciate if anyone can help me. Thanks.
void flow_sensor()
  count = 0;      // Reset the counter so we start counting from 0 again
  interrupts();   //Enables interrupts on the Arduino
  delay (1000);   //Wait 1 second
  noInterrupts(); //Disable the interrupts on the Arduino
  flowRate = (count * 2.25);        //Take counted pulses in the last second and multiply by 2.25mL
  Total_mL = (flowRate + Total_mL);    //Transfer flowrate value to Total_mL
  Total_L = Total_mL / 1000;        //divide by 1000 to get into liters
  flowRate = flowRate * 60;         // mL/minute
  flowRate = flowRate / 1000;       // liters/minute
  Total_G = (Total_mL * 0.000264172052); //convert mL to gallons
void Flow()
   count++; //Every time this function is called, increment "count" by 1
Please post your complete sketch
Why are you enabling and disabling interrupts in the function ?
Does any other part of the sketch use interrupts I wonder ?
I used the following code which I found online. I ran this code on its own and it works. I then put what is in this loop into its own function called void flow_sensor into another sketch which is my main project. My main project sketch is very long and it does not use any other interrupts except this one. When void flow_sensor is called in my main project's sketch loop, it gets stuck in the function. Am I implementing it wrong?
int flowPin = 2;    //input pin 2 for interrupt
double flowRate;    //rate of water flow
double Total_mL;    //total water in Milliliters
double Total_L;     //total water in Liters
double Total_G;     //total water in Gallons
volatile int count; //This integer needs to be set as volatile to ensure it updates correctly during the interrupt process.
  pinMode(flowPin, INPUT_PULLUP);       //sets the pin as an input pullup
  attachInterrupt(0, Flow, RISING);     //Configures interrupt 0 (pin 2 on the Arduino Uno) to run the function "Flow"
  Serial.print("Flow Rate: ");
  Serial.print(flowRate);
  Serial.print(" L/M");
  Serial.print("   Total ");
  Serial.print(Total_mL);
  Serial.print(" mL  ");
  Serial.print(Total_L);
  Serial.print(" Liters ");
  Serial.print(Total_G);
  Serial.println(" Gallons");
void Flow()
You might not be using any interrupts but the program might. For instance, do you print anything or use delay() in the rest of the program ?
