Help With Head Light Flasher Program
Hi All
I’m trying to write a program which performs 2 functions:
  • Turns head-lights on when a rocker switch is pressed
  • Flashes the flights (no matter if head lights are on or off)
I can get the head lights to turn on and off no problem, and i’ve added code to essentially check if the flash button is pressed and then run through the flashing function.
I dont want to use delays as i would like to keep the program running, so i’m using millis()
I have been using a boolean to define if the lights should be on or off, which i can then flip to do the flashing if the lights are either on or off.
This allows me to flash the lights no matter if the headlight switch is on or off.
For some reason this code isn’t working; lights turn on fine, but nothing happens when i press the flash button.
Any help is appreciated.
bool pressedFlash;
bool HLStatus;
unsigned long startFlashMillis;
unsigned long currentFlashMillis;
  pinMode(8, INPUT);
  pinMode(7, OUTPUT);
  pinMode(9, INPUT);
  digitalWrite(7, LOW);
  HLStatus = false; // initial setting to false
  pressedFlash = false;
  startFlashMillis = millis(); // initial start time
void flash() // flash function
  currentFlashMillis = millis(); // flash function start time
  unsigned long flashTime = 200;
  if (digitalRead(9) && !pressedFlash) // if button is pressed and it was not pressed before start flash
    HLStatus = !HLStatus; // flip head light status
    pressedFlash = true; // flash button was pressed
    startFlashMillis = currentFlashMillis; // start timing of flash function
  if (pressedFlash && ((currentFlashMillis - startFlashMillis)>= flashTime))
  if (!pressedFlash)
  	HLStatus = digitalRead(8);
    digitalWrite(7, HLStatus);
  flash();
Have you tried printing the value of pertinent variables before each test on their value is performed ? Are the values what you expect ?
I found it difficult to follow the logic of your program, which was not helped because the inputs are anonymous pin numbers rather than having meaningful names.
How are the switches wired ? Do you have pulldown resistors on the inputs to keep them in a known state ?
UKHeliBob:
I have not done this and to be honest not sure how.
I've replaced the pin numbers with names, see my code below and see if this helps.
I dont have pulldown resistors at the moment as I am testing this digitally first.
Here is the setup to see how it works:
bool pressedFlash;
bool HLStatus;
unsigned const int HLRelayPin = 7;
unsigned const int HLMainPin = 8;
unsigned const int flashPin = 9;
  pinMode(HLMainPin, INPUT);
  pinMode(HLRelayPin, OUTPUT);
  pinMode(flashPin, INPUT);
  digitalWrite(HLRelayPin, LOW);
  if (digitalRead(flashPin) && !pressedFlash) // if button is pressed and it was not pressed before start flashing
  if (pressedFlash && ((currentFlashMillis - startFlashMillis)>= flashTime)) // if flash start and flash time elapsed, flip head light state
  if (!pressedFlash)
  	HLStatus = digitalRead(HLMainPin);
    digitalWrite(HLRelayPin, HLStatus);
  flash();
Without pulldown resistors (10k) from pin to ground, the inputs can float HIGH when the button is not pressed causing "ghost" operation. Why not wire the switches from GND to input pin and use:
pinMode(HLMainPin, INPUT_PULLUP);
The logic will be inverted so it's LOW when the button is pressed, HIGH otherwise, no resistors needed.
outsider:
The logic will be inverted so it's LOW when the button is pressed, HIGH otherwise.
Thanks for the suggestion, I will probably do that once I have an Arduino to play with.
I managed to get it to work with the following code.
My issue was I wasn't outputting the status of the head light at each loop so the flashing function was running but I coudnt see the results.
Secondly I need a check at each flash so that the correct flash timing is done without interrupting the loop.
bool pressedFlash;
bool HLStatus;
bool didFirstFlash;
bool didSecondFlash;
bool didThirdFlash;
bool didFourthFlash;
  pinMode(HLMainPin, INPUT); // main head light switch pin
  pinMode(HLRelayPin, OUTPUT); // relay which control head light pin
  pinMode(flashPin, INPUT); // flash button pin
  digitalWrite(HLRelayPin, LOW); // initial LOW setting
  // flash function parameters
  pressedFlash = false; // initial setting to false
  didFirstFlash = false;
  didSecondFlash = false;
  didThirdFlash = false;
  didFourthFlash = false;
  if (!pressedFlash) // if flash button was not pressed before (first flash)
    startFlashMillis = currentFlashMillis; // start timing of first flash
  if (pressedFlash && ((currentFlashMillis - startFlashMillis) >= flashTime)) // if first flash time elapsed, flip head light state
    didFirstFlash = true;
  if (didFirstFlash && ((currentFlashMillis - startFlashMillis) >= (2*flashTime))) // if second flash time elapsed, flip head light state
    didSecondFlash = true;
  if (didSecondFlash && ((currentFlashMillis - startFlashMillis) >= (3*flashTime))) // if third flash time elapsed, flip head light state
    didThirdFlash = true;
  if (didThirdFlash && ((currentFlashMillis - startFlashMillis) >= (4*flashTime))) // if fourth flash time elapsed, flip head light state
    didFourthFlash = true;
  if (didFourthFlash && ((currentFlashMillis - startFlashMillis) >= (5*flashTime))) // if fifth flash time elapsed, flip head light state
  digitalWrite(HLRelayPin, HLStatus); // head lights status driven by HLStatus
  if (!pressedFlash) // if the flash button was not pressed, check head light status from main switch
    HLStatus = digitalRead(HLMainPin); // set HLStatus to main head light switch
  if (digitalRead(flashPin) || pressedFlash) // if the flash button is pressed or was pressed (before resetting) then do flash function
  flash();
I would like to try and make the code more efficient now as it seems pretty long and complex to do what i thought would be a simple task.
I assume you're working on a simulator? :slight_smile:
Do you want a certain number of flashes or flash as long as the button is pressed?
outsider:
I assume you’re working on a simulator? :slight_smile:
Yes, using simulator.
The program was to make a certain number of flashes once pressed and then revert back to the main switch
