help with hex
I am trying to us iremote library for menu buttons on my project when I push a button it gets put into results and I look at that to see if it is the button I pressed the problem is it keeps doing that button over and over again I need to make results go back to 0 or something other then the last button I pressed here is my code let me know if you have any ideas
results seems to be a hex data type and I have no idea how to deal with it
if (irrecv.decode(&results)) { irup = false; if (results.value == 0xB54A02FD) irup = true; irdown = false; if (results.value == 0xB54A827D) irdown = true; irmenu = false; if (results.value == 0xB54A9867) irmenu = true; irrecv.resume(); // Receive the next value
I tried adding the following at the bottom of this to reset results but I cant get it to reset results = 0; // does not compile String results = String(0x0); does nothing results.value = 0x00000000; does nothing
this one compiles
#include <IRremote.h>
int RECV_PIN = A1;
int OUTPUT_PIN = 13;
boolean up,down,menu;
IRrecv irrecv(RECV_PIN);
decode_results results;
pinMode(OUTPUT_PIN, OUTPUT);
pinMode(13, OUTPUT);
irrecv.enableIRIn(); // Start the receiver
int on = 0;
unsigned long last = millis();
up = false;
if (results.value == 0xB54A02FD) up = true;
down = false;
if (results.value == 0xB54A827D) down = true;
menu = false;
if (results.value == 0xB54A9867) menu = true;
if (irrecv.decode(&results)) {Serial.print(“0x”),
Serial.println(results.value, HEX);
if(up || menu) digitalWrite(OUTPUT_PIN, HIGH);
if(down) digitalWrite(OUTPUT_PIN, LOW);
I added curley braces :"
void loop() { if (irrecv.decode(&results)) { up = false; if (results.value == 0xB54A02FD) {up = true; down = false;} if (results.value == 0xB54A827D) {down = true; menu = false;} if (results.value == 0xB54A9867){ menu = true; irrecv.resume(); }// Receive the next value
Maybe you needed curly braces to separate blocks of logic. Maybe not.
didnt work
the buttons are working the problem is they repeat every scan till I push a different button on the remote
So after you get a good results value & do the action, set set results value to something that is not valid, then no further actio will occur until another good results value occurs.
changing the value of "results" to something that is not valid is the first thing I tried but I dont know how to change it
Try this
    up = false;
up = true;
    down = false;
results.value = 0;
{ down = true;
    menu = false;
results.value = 0;
{ menu = true;
results.value = 0;
Serial.print("0x"),
results.value = 0;
no response from the remote now
Well, I must admit I don't really know what you're doing then.
i figured it out changed it to this notice I am changing to false out side of the if statement oops my fault irup = false; irdown = false; irmenu = false;
if (irrecv.decode(&results)) { if (results.value == 0xB54A02FD) irup = true; if (results.value == 0xB54A827D) irdown = true; if (results.value == 0xB54A9867) irmenu = true; irrecv.resume(); // Receive the next value
