As of right now my HM55B compass is printing constant data to processing from -180 to 0N to 180. How would I modify the following code to only output 8 directions. N, NE, E, SE, S, SW, W, NW?
#include <math.h> // (no semicolon)
//// VARS
byte CLK_pin = 8;
byte EN_pin = 9;
byte DIO_pin = 10;
byte LED = 13;
int ZeroOffset = 0; // To calibrate the compass, run in uncalibrated mode [Section 1],
// point the sensor due North, and record the value sensed.
// Enter that value here and then run in calibrated mode [Section 2]
int X_Data = 0;
int Y_Data = 0;
int angle, status;
float Delta, xPrime, yPrime;
//// FUNCTIONS
void ShiftOut(int Value, int BitsCount) {
for(int i = BitsCount; i >= 0; i--) {
digitalWrite(CLK_pin, LOW);
if ((Value & 1 << i) == ( 1 << i)) {
digitalWrite(DIO_pin, HIGH);
//Serial.print("1");
else {
digitalWrite(DIO_pin, LOW);
//Serial.print("0");
digitalWrite(CLK_pin, HIGH);
delayMicroseconds(1);
int ShiftIn(int BitsCount) {
int ShiftIn_result;
ShiftIn_result = 0;
pinMode(DIO_pin, INPUT);
if (digitalRead(DIO_pin) == HIGH) {
ShiftIn_result = (ShiftIn_result << 1) + 1;
//Serial.print("x");
else {
ShiftIn_result = (ShiftIn_result << 1) + 0;
//Serial.print("_");
//Serial.print(":");
// below is difficult to understand:
// if bit 11 is Set the value is negative
// the representation of negative values you
// have to add B11111000 in the upper Byte of
// the integer.
// see: http://en.wikipedia.org/wiki/Two%27s_complement
if ((ShiftIn_result & 1 << 11) == 1 << 11) {
ShiftIn_result = (B11111000 << 8) | ShiftIn_result;
return ShiftIn_result;
void HM55B_Reset() {
pinMode(DIO_pin, OUTPUT);
digitalWrite(EN_pin, LOW);
ShiftOut(B0000, 3);
digitalWrite(EN_pin, HIGH);
void HM55B_StartMeasurementCommand() {
ShiftOut(B1000, 3);
int HM55B_ReadCommand() {
int result = 0;
ShiftOut(B1100, 3);
result = ShiftIn(3);
return result;
pinMode(EN_pin, OUTPUT);
pinMode(CLK_pin, OUTPUT);
HM55B_Reset();
HM55B_StartMeasurementCommand(); // necessary!!
delay(40); // the data is 40ms later ready
status = HM55B_ReadCommand(); // read data
X_Data = ShiftIn(11); // Field strength in X
Y_Data = ShiftIn(11); // and Y direction
digitalWrite(EN_pin, HIGH); // Deselect chip
// [Section 1: Simple Angle calculation]
// To determine the angle using the raw sensor data, we can simply calculate
// the Inverse Tangent of Y_Data/X_Data. Uncomment the following line and comment
// all of [Section 2]
// angle = (180 * (atan2(-1 * Y_Data , X_Data) / M_PI)); // angle is atan( -y/x) !!!
// [End Section 1]
// [Section 2: Offset-Compensated Angle Calculation]
// To better match the compass readings with well known values of true north,
// you can use the following calculations to rotate the value of the tangent
// before determining the angle. To do this, we first need to run the program
// with the code in [Section 1] uncommented and note the angle value when we
// point the sensor to true north. Enter the value recorded at the top of
// this program in the variable "ZeroOffset", comment the code in [Section 1],
// and uncomment the code below.
Delta = (ZeroOffset/180.0)*M_PI; // Calculate radians from degrees
xPrime = X_Data*cos(Delta) - Y_Data*sin(Delta); // Translate the X_Data value based on
// rotating the original angle by "Delta" rads.
yPrime = Y_Data*cos(Delta) + X_Data*sin(Delta); // Translate the Y_Data value based on
angle = (180 * (atan2(-1 * yPrime , xPrime) / M_PI)); // angle is still atan(-y/x)
// [End Section 2]
if (abs(angle) < 10) {
digitalWrite (LED, HIGH);
digitalWrite (LED, LOW);
Serial.println(angle); // print angle
delay(100);
