Hello,
I am having some problems porting the below code, that works great. I would include all the code, but let me start here first.
When I port this code to my new project, the htm file gets sent, and I can see it when I “view page source” in the browser. It looks identical to what gets served in the working code.
It just seems like it has lost its brains as to where to access the scripts or png files, etc, or I am just missing something else fundamentally.
Can someone help me understand what is going on? Thanks ahead of time.
Sorry ahead of time for some of the “work-in-progress” commented lines and somewhat newbie architecture.
Below is the code that works. (from aaron at the Roaming Coder) I had to slightly update for use with Arduino 1.0, but pretty minor. I also removed the TimeServer parts, for simplicity, but this code works to simply list the files on the SD card and select an htm file to display and run the javascripts. I really liked this because it seemed really an easy way to graph my weather data that I collect on the SD card.
#include <SPI.h>
#include <SD.h>
#include <Ethernet.h>
/************ ETHERNET STUFF ************/
byte mac[] = { 0x, 0x, 0x, 0x, 0x, 0x }; // my MAC is inserted
byte ip[] = { 192, 168, 0, 50 };
EthernetServer server(XXXX); // My forwarded Port is inserted
/************ SDCARD STUFF ************/
Sd2Card card;
SdVolume volume;
SdFile root;
File file;
const int chipSelect = 4;
const int temp_pin = 0;
const int light_pin = 1;
unsigned long sample_delay_interval = 600000; //one minute
unsigned long last_temp_sample_millis = 0;
String TempString = "";
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
// analogReference(INTERNAL);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_FULL_SPEED, chipSelect)) error("card.init failed!");
SD.begin(chipSelect);
// initialize a FAT volume
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
if (!root.openRoot(&volume)) error("openRoot failed");
// list file in root with date and size
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
PgmPrintln("Done");
// Debugging complete, we start the server!
Ethernet.begin(mac, ip);
server.begin();
void ListFiles(EthernetClient client, uint8_t flags) {
// This code is just copied from SdFile.cpp in the SDFat library
// and tweaked to print to the client output in html!
dir_t p;
root.rewind();
client.println("<ul>");
while (root.readDir(p) > 0) {
// done if past last used entry
if (p.name[0] == DIR_NAME_FREE) break;
// skip deleted entry and entries for . and ..
if (p.name[0] == DIR_NAME_DELETED || p.name[0] == '.') continue;
// only list subdirectories and files
if (!DIR_IS_FILE_OR_SUBDIR(&p)) continue;
// print any indent spaces
client.print("<li><a href=\"");
for (uint8_t i = 0; i < 11; i++) {
if (p.name[i] == ' ') continue;
if (i == 8) {
client.print('.');
client.write(p.name[i]);
client.print("\">");
// print file name with possible blank fill
if (i == 8) {
client.print('.');
client.print("</a>");
if (DIR_IS_SUBDIR(&p)) {
client.print('/');
// print modify date/time if requested
if (flags & LS_DATE) {
root.printFatDate(p.lastWriteDate);
client.print(' ');
root.printFatTime(p.lastWriteTime);
// print size if requested
if (!DIR_IS_SUBDIR(&p) && (flags & LS_SIZE)) {
client.print(' ');
client.print(p.fileSize);
client.println("</li>");
client.println("</ul>");
// How big our line buffer should be. 100 is plenty!
#define BUFSIZ 100
char clientline[BUFSIZ];
int index = 0;
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
// reset the input buffer
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// If it isn't a new line, add the character to the buffer
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
// are we too big for the buffer? start tossing out data
if (index >= BUFSIZ)
index = BUFSIZ -1;
// continue to read more data!
continue;
// got a \n or \r new line, which means the string is done
clientline[index] = 0;
// Print it out for debugging
Serial.println(clientline);
// Look for substring such as a request to get the root file
if (strstr(clientline, "GET / ") != 0) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
// print all the files, use a helper to keep it clean
client.println("<h2>Files:</h2>");
ListFiles(client, LS_SIZE);
} else if (strstr(clientline, "GET /") != 0) {
// this time no space after the /, so a sub-file!
char *filename;
filename = clientline + 5; // look after the "GET /" (5 chars)
// a little trick, look for the " HTTP/1.1" string and
// turn the first character of the substring into a 0 to clear it out.
(strstr(clientline, " HTTP"))[0] = 0;
// print the file we want
Serial.println(filename);
file = SD.open(filename);
if (!file) {
client.println("HTTP/1.1 404 Not Found");
client.println();
client.println("<h2>File Not Found!</h2>");
Serial.println("Opened!");
//Set appropriate mime type based on file extension
String fname = String(filename);
int dotat = fname.lastIndexOf('.');
String extension = String("");
if(dotat > -1){
extension = String(fname.substring(dotat+1));
extension.toLowerCase();
Serial.print("extension is ");
Serial.println(extension);
if(extension == "htm"){
else if(extension == "js"){
client.println("Content-Type: application/x-javascript");
else if(extension == "css"){
client.println("Content-Type: text/css");
else if(extension == "jpg"){
client.println("Content-Type: image/jpeg");
else if(extension == "gif"){
client.println("Content-Type: text/gif");
else if(extension == "png"){
client.println("Content-Type: image/png");
else{
client.println("Content-Type: text/plain");
client.println();
char c;
while (file.available()) {
c = file.read();
client.print(c);
file.close();
// everything else is a 404
client.println();
// give the web browser time to receive the data
delay(1);
client.stop();
