Help with humidity sensor RHU-222
Hello to all!
I'm really new to arduino and sensors. I've this humidity sensor RHU-222. Detailed specifications can be found here: http://www.desantix.it/dataSheet/RHU-222serie.pdf
I've attached:
pin1 to 5V of arduino pin2 to analog of arduino (pin4) pin3 to ground
NOTHING else.
The output should be a value between 0.7 and 2.81 but I obtain values more or less between 200.
First: Do I have connected this sensor correctly? Second: Do I need to do more operations and manipolations of the obtained value?
It seems that if I breath on the sensor, the values changes.
I've not well understood how to read the tech spec as well, maybe I've done a mistrake.
Thank's!
Simon
The code:
float raw0;
int Pin0 = 4;
Serial.println("starting");
  raw0 = analogRead(Pin0);
  Serial.print("Raw: ");
  Serial.println(raw0);
You haven't done anything to map the 0..1023 range of the analogRead to your 0.7 to 2.81 range.
(FYI 200 / 1024 * 5 = 0.977)
Is the raw value * 5 (voltage) / 1024 = current readed voltage from analog?
Thank you!!! :)
Simon
