Help with if statements
how can i get this to work with my script. without cutting off the other half of the loop?
 if (digitalRead(fanrelay) != HIGH)
    delay(1);
    Serial.println ("fan relay on");
    fancounter = fancounter + 1;
    Serial.println(fancounter);
      while (digitalRead(fanrelay) != HIGH)
        delay(1);
    if (digitalRead(pumprelay) != HIGH)
    delay(1);
    Serial.println ("pump relay on");
    pumpcounter = pumpcounter + 1;
    Serial.println(pumpcounter);
      while (digitalRead(pumprelay) != HIGH)
        delay(1);
     if (digitalRead(drainrelay) != HIGH)
    delay(1);
    Serial.println ("drain relay on");
    draincounter = draincounter + 1;
    Serial.println(draincounter);
      while (digitalRead(drainrelay) != HIGH)
        delay(1);
notsolowki:
okay so i added this to the void setup() " interval2 = pumpoffInterval;"
and that took care of it? i wish i knew exactly why.?!? now i guess its time to get my counter to work. i know each relay has its own interval. the fan is interval and the pump is interval2
Because in your original code you had
unsigned long interval2=0;
and it was not set to more. So as soon as the code got to
if (currentMillis - previousMillis > interval2)
it was true and executed turning the pump on. When you set intervat2 in setup() to something larger it waits for the time to expire before it starts the pump.
But I noticed another bug in your code: you need two previousMillis variables - one for pump and one for fan. This way it will not work as I think you want it to work (it will only turn on and off the fan and will never turn on the pump because the fan part will always update previousMillis before pump is ready to start...)
EDIT:
notsolowki:
while (digitalRead(drainrelay) != HIGH) delay(1);
is evil. It stucks the program until the drainrelay goes HIGH. But since the program is stuck in this endless loop it will never get to the part where it will do it. You need remove this part and save to a variable you already reported this happened ("set a flag"). Then in each main loop iteration you check if drainrelay went HIGH. If so "clear the flag" - write the variable to its "idle" value.
this is what my setup part of the code looks like now,
  interval = offInterval;
  interval2 = pumpoffInterval; //new
  pinMode (drainbutton, INPUT_PULLUP); //DRAIN ACTIVATION PIN
  pinMode (fanrelay, OUTPUT); //FAN POWER RELAY
  pinMode (pumprelay, OUTPUT); //WATER PRESSURE PUMP
  pinMode (drainrelay, OUTPUT); //DRAIN SOLENOID POWER RELAY
  digitalWrite(pumprelay, HIGH); //SET INITAL RELAY STATE
  digitalWrite(fanrelay, HIGH); //SET INITAL RELAY STATE
  digitalWrite(drainrelay, HIGH); //SET INITAL RELAY STATE
  digitalWrite(drainbutton, HIGH); //SET INITAL BUTTON STATE
  Serial.print("Ready");
i wish i could just get the button counter to work. i have it sending message over serial through an esp8266 to a telnet session. to relay the data to me. i have no practical reason to do this but it just interests me.
Here's a way to count how many times the pump comes on:
 //DRAIN CYCLE
  currentTime = millis();
  previousdrainbuttonState = currentdrainbuttonState;
  currentdrainbuttonState = digitalRead(pumprelay); //ASK STATE OF DRAIN BUTTON
  if (currentdrainbuttonState != previousdrainbuttonState && currentdrainbuttonState == LOW)//ASK WHATS THE STATE OF THE Pump
  if (currentdrainbuttonState != previousdrainbuttonState && currentdrainbuttonState == HIGH)//ASK WHATS THE STATE OF THE BUTTON
    startTime = millis();
    digitalWrite(drainrelay, LOW);//TURN IT ON
  if (currentTime - startTime >= period) //ASK HOW LONG TO STAY ON
    digitalWrite(drainrelay, HIGH); //DEBOUNCE
    delay(50);
Checks state change as suggested earlier.
i have this section for the pump millis.
unsigned long interval2 = 0;
unsigned long pumppreviousMillis = 0;
unsigned long pumponInterval = 1000; // spray on time 26 SECONDS
unsigned long pumpoffInterval = 1000; // sprayer off time 1.8 HRS
on the pump sysle this is how i have it,
if (currentMillis - previousMillis > interval2) {
    pumppreviousMillis = currentMillis;
    if (pumprelayState == HIGH) { //IF ITS OFF
      pumprelayState = LOW; // TURN IT ON
      interval2 = pumponInterval; //ASK HOW LONG TO TURN IT ON
    else {
      pumprelayState = HIGH; //OTHERWISE TURN IT OFF
      interval2 = pumpoffInterval; //ASK HOW LONG TO TURN IT OFF
    digitalWrite(pumprelay, pumprelayState); //DEBOUNCE
    delay(50);
one thing i dont understand is
]if (currentMillis - previousMillis > interval2) {
how is this going to work along side the fan relay millis. for the pump if i change (currentMillis - previousMillis > interval2) { to (currentMillis - pumppreviousMillis > interval2) { the pump timer dont work right. im not sure if it will work right at all like your saying. thankyou for helping me
wildbill:
 //DRAIN CYCLE
    delay(50);
thankyou soo much for this. now that i have a working script i can try to learn more about the way it functions.
As hinted at above, This:
Should probably be:
if (currentMillis - pumppreviousMillis > interval2) {
It's probably worth renaming previousMillis to fanpreviousMillis too.
i know that what i thought too, but when i change it to if (currentMillis - pumppreviousMillis > interval2) {
the pump timer dont work.?!?!
i do notice though that if i set both relays to kick on at 500ms they do not kick on right. they dont need to switch like that, but it just means something must not be right but i dont know why i cant change previousmillis to pumppreviousmillis
Time to post your latest version then.
sure thing, one thing i do want to point out. is to make it easier for me wiring wise i set 2 pins as A1
//READ ONLY BUTTON CONFIGURATION
const int pumprelay = A1;
const int drainbutton = A1;
const int fanrelay = A0;
const int drainrelay = A4;
//INITAL PINSTATES
int fanlastState = HIGH;
int draincounter = 0;
int pumpcounter = 0;
int fancounter = 0;
int drainrelayState = HIGH;
int fanrelayState = HIGH;
int pumprelayState = HIGH;
int drainbuttonState = HIGH;
//FAN ON/OFF CYCLE
unsigned long previousMillis = 0; //
unsigned long interval = 0; //
unsigned long onInterval = 138000UL; //  FAN ON TIME 2.3 MINUTES
unsigned long offInterval = 1800000UL; // FAN OFF TIME 30 MINUTES
//PUMP ON/OFF CYCLE
unsigned long pumponInterval = 36000UL; // spray on time 26 SECONDS
unsigned long pumpoffInterval = 6480000UL; // sprayer off time 1.8 HRS
//DRAIN RELAY ON TIME
unsigned long startTime;
unsigned long currentTime;
unsigned long period = 2000; //DRAIN OPEN TIME
int previousdrainbuttonState = HIGH;
int currentdrainbuttonState = HIGH;
  //FAN CYCLE
  if (currentMillis - previousMillis > interval) {
    if (fanrelayState == HIGH) { //IF ITS OFF
      fanrelayState = LOW; // THEN TURN ON
      interval = onInterval; // ASK HOW LONG TO STAY ON
    else {
      fanrelayState = HIGH; // OTHERWISE OFF
      interval = offInterval; //ASK HOW LONG TO STAY OFF
    digitalWrite(fanrelay, fanrelayState); //UPDATE STATUS OF FAN
//PUMP CYCLE
    else {
    delay(50);
  //DRAIN CYCLE
    delay(50);
I made the change to use pumppreviousMillis, added some serial.prints, reduced your intervals substantially and tried it out. Both pump and fan worked.
There is a problem though, the drain doesn't stay on. this was the fix:
  if (((millis() - StartTime) >= DrainPeriod)&& digitalRead(drainrelay)==LOW) //ASK HOW LONG TO STAY ON
    Serial.println("Drain stop");
    delay(50);
notsolowki:
//INITAL PINSTATES
int fancounter = 0;
//FAN ON/OFF CYCLE
//PUMP ON/OFF CYCLE
//FAN CYCLE
   else {
//PUMP CYCLE
else {
   delay(50);
 //DRAIN CYCLE
   delay(50);
You still have this wrong:
you need to use pumppreviousMillis in the if condition.
It is OK that both pins are A1 in this application. In fact it is "clever". When you decide drainbutton should not be driven by pumprelay but from something else (i.e. real button) you can simply set it on another pin and everything will work provided you wrote your code properly.
sorry guys i fell asleep lol. i woke up this morning and the fan was the only thing that was cycling. i changed previousmillis to pumprpeviousmillis and actually watched the relay leds and your right it does work. i think its because i was listening for the relay click but the drain was staying open because its duration was longer than any other duration so it just stayed on and i mistook that for a bug. and serial print is working. i wondered why it didnt count with the button? well thats because millis is the only thing that activates the count, lol noob moment. thanks for all the help guys. sometime today i would like to try to convert pump time on in ms to liter of water per minute and have it give me an estimated amount of water output. thanks again everyone for being patient with me.
hi everyone, i am having another problem with my code. the problem im having is when i add the the bottom part of the code "MIST CIRCULATION AFTER PUMP OFF" my fan relays come on the first time properly, then the second time they come on about half as long. then eventually the relay for the fan just kicks on and off really fast. in my serial console i get "pump cycle complete" a whole bunch of times. can someone point out the bug please, if i remove the whole part of the code "MIST CIRCULATION AFTER PUMP OFF" then it work properly. thank you
//INITAL PINSTATES
int fancounter = 0;
//FAN ON/OFF CYCLE
unsigned long onInterval = 6000; //  FAN ON TIME 5 MINUTES 240000UL
unsigned long offInterval = 10000; // FAN OFF TIME 22 MINUTES 1320000UL
//PUMP ON/OFF CYCLE
unsigned long pumponInterval = 36000UL; // spray on time 26 SECONDS 36000UL
unsigned long pumpoffInterval = 6480000UL; // sprayer off time 1.8 HRS 6480000UL
unsigned long period = 4000; //DRAIN OPEN TIME
//MIST CIRUATION CONTROLL AFTER PUMPOFF
unsigned long fanstartTime;
unsigned long fancurrentTime;
unsigned long fanperiod = 30000 ; //FAN CIRCULATE ON TIME
int fanpreviousrelayState = HIGH;
int fancurrentrelayState = HIGH;
  //FAN CYCLE
    else {
  //PUMP CYCLE
      digitalWrite(fanrelay, LOW);
    else {
    delay(50);
  //DRAIN CYCLE
    delay(50);
  //MIST CIRCULTION AFTER PUMP OFF //HAVING PROBLEMS\\\
  fancurrentTime = millis();
  fanpreviousrelayState = fancurrentrelayState;
  fancurrentrelayState = digitalRead(pumprelay); //ASK STATE OF DRAIN BUTTON
  if (fancurrentrelayState != fanpreviousrelayState && fancurrentrelayState == HIGH)//ASK WHATS THE STATE OF THE BUTTON
    fanstartTime = millis();
    digitalWrite(fanrelay, LOW);//TURN IT ON
  if (fancurrentTime - fanstartTime >= fanperiod) //ASK HOW LONG TO STAY ON
  digitalWrite(fanrelay, HIGH); //DEBOUNCE
    Serial.println("Pump cycle complete");
    delay(50);
i have updated the code. here is the part of the script causing issues,, it seems to turn on and then off right away without wait for the on time. how is fancurrenttime and fanstarttime = to fan period of 2000ms. it seems to ignore if (fancurrentTime - fanstartTime >= fanperiod) or im looking at it wrong. help!!! :slight_smile:
    delay(50);
please help me!!
    delay(50);
Once the condition in the if test is true what will stop it being true the next time the test is executed ?
actually to my relays HIGH is off and LOW is on. so that part that you just quoted is to turn it off.so we have this script
    delay(50);
this is supposed to run the fan for an amount of time after the pump shuts off. instead it comes on then off right away and "pump cycle complete" keeps blowing up my serial session. it keeps setting it HIGH. i have it working right now like this
   //mist CYCLE
  mistcurrentTime = millis();
  previousmistbuttonState = currentmistbuttonState;
  currentmistbuttonState = digitalRead(pumprelay); //ASK STATE OF DRAIN BUTTON
  if (currentmistbuttonState != previousmistbuttonState && currentmistbuttonState == HIGH)//ASK WHATS THE STATE OF THE BUTTON
    miststartTime = millis();
    digitalWrite(mistbutton, LOW);//TURN IT ON
    delay(5000);
    digitalWrite(mistbutton, HIGH);
but im not sure what other bugs are going to popup
i better give an updated copy of my sloppy script who's names correlate with mist.
const int mistbutton = A0;
//INITAL PINSTATES
int mistbuttonState = HIGH;
int fancounter = 0;
//FAN ON/OFF CYCLE
unsigned long onInterval = 240000UL; //  FAN ON TIME 5 MINUTES 240000UL
unsigned long offInterval = 1320000UL; // FAN OFF TIME 22 MINUTES 1320000UL
//PUMP ON/OFF CYCLE
//CIRUATION CONTROLL AFTER PUMPOFF
unsigned long interval3 = 0;
unsigned long miststartTime;
unsigned long mistcurrentTime;
unsigned long mistperiod = 2000; //DRAIN OPEN TIME
int previousmistbuttonState = HIGH;
int currentmistbuttonState = HIGH;
interval3 = mistperiod;
  pinMode (mistbutton, INPUT_PULLUP);
  digitalWrite(drainbutton, HIGH);//SET INITAL BUTTON STATE
  //FAN CYCLE
    else {
  //PUMP CYCLE
    else {
    delay(50);
  //DRAIN CYCLE
    delay(50);
   //mist CYCLE
    delay(5000);
Ive been looking at this basic example of an if statement.
if (pinFiveInput < 500)
// action A
// action B
when you look at my code. if i change
    delay(5000);
to
if (mistcurrentTime - miststartTime >= mistperiod) //ASK HOW LONG TO STAY ON
  digitalWrite(mistbutton, HIGH); //DEBOUNCE
    delay(50);
then it continues to run part b of that if statement over and over again.
