Help with implementing a DC Motor with PID Encoder
Hello,
we have the following Code. And we want to plot the encoder reading versus the input target positions. But it only displays the Input target position, although we tested the encoder several times before implementation and quite sure it's working.
#define ENCA 6 // YELLOW
#define ENCB 7 // WHITE
#define PWM 9
#define IN2 2
#define IN1 3
volatile int posi = 0;
long prevT = 0;
float eprev = 0;
float eintegral = 0;
  pinMode(ENCA,INPUT);
  pinMode(ENCB,INPUT);
  attachInterrupt(digitalPinToInterrupt(ENCA),readEncoder,RISING);
  pinMode(PWM,OUTPUT);
  pinMode(IN1,OUTPUT);
  pinMode(IN2,OUTPUT);
  Serial.println("target pos");
  // set target position
 // int target = 1200;
  int target = 250*sin(prevT/1e6);
  // int target = analogRead(A1);
  // PID constants
  float kp = 1.0;
  float kd = 0.05;
  float ki = 0.001;
  // time difference
  long currT = micros();
  float deltaT = ((float) (currT - prevT))/( 1.0e6 );
  prevT = currT;
int pos = 0;
  noInterrupts(); // disable interrupts temporarily while reading
  pos = posi;
  interrupts(); // turn interrupts back on
  // error
  int e = pos-target;
  // derivative
  float dedt = (e-eprev)/(deltaT);
  // integral
  eintegral = eintegral + e*deltaT;
  // control signal
  float u = kp*e + kd*dedt + ki*eintegral;
  // motor power
  float pwr = fabs(u);
  if( pwr > 255 ){
    pwr = 255;
  // motor direction
  int dir = 1;
  if(u<0){
    dir = -1;
  // signal the motor
  setMotor(dir,pwr,PWM,IN1,IN2);
  // store previous error
  eprev = e;
  Serial.print(target);
  Serial.print(" ");
  Serial.print(pos);
delay(100);
void setMotor(int dir, int pwmVal, int pwm, int in1, int in2){
  analogWrite(pwm,pwmVal);
  if(dir == 1){
    digitalWrite(in1,HIGH);
    digitalWrite(in2,LOW);
  else if(dir == -1){
    digitalWrite(in1,LOW);
    digitalWrite(in2,HIGH);
  else{
void readEncoder(){
  int b = digitalRead(ENCB);
  if(b > 0){
    posi++;
  else{
    posi--;
Please read the link and update Your post. Link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
