Help with inputting data into webserver
Hi all.
I've been trying to figure this out for a few hours now, and I'm hitting a dead wall.
I'm trying to combine two sketches that work perfectly alone, but I can't figure out how to make the webserver display the temps.
The sketch as is:
#include <SPI.h>
#include <Ethernet.h>
#include <avr/pgmspace.h>
#include <string.h>
#include <OneWire.h>
#include <DallasTemperature.h>
*                                   MAC address and IP address.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 105 };
*                                   Memory space for string management and setup WebServer service
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer = { 0x28, 0x6B, 0x58, 0x5D, 0x04, 0x00, 0x00, 0x55 };
DeviceAddress outsideThermometer = { 0x28, 0xFD, 0xA0, 0x5C, 0x04, 0x00, 0x00, 0x41};
DeviceAddress dogHouseThermometer = { 0x28, 0x35, 0x39, 0x5D, 0x04, 0x00, 0x00, 0xB4 };
DeviceAddress Freezer = {0x28, 0x3B, 0x7F, 0x5D, 0x04, 0x00, 0x00, 0xD2};
// For sending HTML to the client
#define STRING_BUFFER_SIZE 128
char buffer[STRING_BUFFER_SIZE];
// to store data from HTTP request
#define STRING_LOAD_SIZE 128
char load[STRING_LOAD_SIZE];
// POST and GET variables
#define STRING_VARS_SIZE 128
char vars[STRING_VARS_SIZE];
*                                   Strings stored in flash of the HTML we will be transmitting
#define NUM_PAGES 5
// HTTP Request message
PROGMEM prog_char content_404[] = "HTTP/1.1 404 Not Found\nServer: arduino\nContent-Type: text/html\n\n<html><head><title>Arduino Web Server - Error 404</title></head><body><h1>Error 404: Sorry, that page cannot be found!</h1></body>";
PGM_P page_404[] PROGMEM = { content_404 }; // table with 404 page
// HTML Header for pages
PROGMEM prog_char content_main_header[] = "HTTP/1.0 200 OK\nServer: arduino\nCache-Control: no-store, no-cache, must-revalidate\nPragma: no-cache\nConnection: close\nContent-Type: text/html\n";
PROGMEM prog_char content_main_top[] = "<html><head><title>St Marks Temperatures</title><style type=\"text/css\">table{border-collapse:collapse;}td{padding:0.25em 0.5em;border:0.5em solid #C8C8C8;}</style></head><body><h1>St Marks Temperatures</h1>";
PROGMEM prog_char content_main_menu[] = "<table width=\"500\"><tr><td align=\"center\"><a href=\"/\">Live Tempuratures</a></td><td align=\"center\"><a href=\"page2\">Tempurature Logs</a></td><td align=\"center\"><a href=\"page3\">Emails for Alerts</a></td><td align=\"center\"><a href=\"page4\">Probably delete</a></td></tr></table>";
PROGMEM prog_char content_main_footer[] = "</body></html>";
PGM_P contents_main[] PROGMEM = { content_main_header, content_main_top, content_main_menu, content_main_footer }; // table with 404 page
#define CONT_HEADER 0
#define CONT_TOP 1
#define CONT_MENU 2
#define CONT_FOOTER 3
// Page 1
PROGMEM prog_char http_uri1[] = "/";
PROGMEM prog_char content_title1[] = "<h2>Live Temperatures</h2>";
PROGMEM prog_char content_page1[] = "<hr /><h3>.</h3><p>Soon to be temps.);</p>
<form action=\"/login\" method=\"POST\"><input type=\"text\" name=\"prova\"><input type=\"submit\" value=\"post\"></form>";
// Page 2
PROGMEM prog_char http_uri2[] = "/page2";
PROGMEM prog_char content_title2[] = "<h2>Temp logs</h2>";
PROGMEM prog_char content_page2[] = "<hr /><h3>.</h3><p>Soon to be temperatures!.</p>";
// Page 3
PROGMEM prog_char http_uri3[] = "/page3";
PROGMEM prog_char content_title3[] = "<h2>Page 3</h2>";
PROGMEM prog_char content_page3[] = "<hr /><h3>.</h3><p>Possible temp logs. (will take some thinking.</p>";
// Page 4
PROGMEM prog_char http_uri4[] = "/page4";
PROGMEM prog_char content_title4[] = "<h2>Page 4</h2>";
PROGMEM prog_char content_page4[] = "<hr /><h3>.</h3><p>May not need page 4.</p>";
// Page 5
PROGMEM prog_char http_uri5[] = "/login";
PROGMEM prog_char content_title5[] = "<h2>POST Page 5</h2>";
PROGMEM prog_char content_page5[] = "<hr /><h3>Content of Page 5</h3><p>received a POST request</p>";
// declare tables for the pages
PGM_P contents_titles[] PROGMEM = { content_title1, content_title2, content_title3, content_title4, content_title5 }; // titles
PGM_P http_uris[] PROGMEM = { http_uri1, http_uri2, http_uri3, http_uri4, http_uri5 }; // URIs
PGM_P contents_pages[] PROGMEM = { content_page1, content_page2, content_page3, content_page4, content_page5 }; // real content
*                                        define HTTP return structure ID for parsing HTTP header request
struct HTTP_DEF {
  int pages;
  char vars[STRING_VARS_SIZE]; //size needs to match the global variable 'vars' otherwise program crashes due to index overrun
*                                                        Shared variable
EthernetServer server(80);
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.begin(9600); // DEBUG
    // Start up the library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(insideThermometer, 8);
  sensors.setResolution(outsideThermometer, 8);
  sensors.setResolution(dogHouseThermometer, 8);
  sensors.setResolution(Freezer, 8);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00) {
    Serial.print("Error getting temperature");
    Serial.print("C: ");
    Serial.print(tempC + 1.5);
*                                                           Main loop
  if (client) { // now client is connected to arduino
    // read HTTP header request... so select what page client are looking for
    HTTP_DEF http_def = readHTTPRequest(client);
    if (http_def.pages > 0) {
      sendPage(client,http_def);
      contentPrinter(client,(char*)pgm_read_word(&(page_404[0])));
    // give the web browser time to receive the data
    delay(1);
    client.stop();
Sorry about the double post, but it wouldn't let me post all the code in one go.
Here's the second half:
*                                              Method for read HTTP Header Request from web client
struct HTTP_DEF readHTTPRequest(EthernetClient client) {
  char c;
  int i;
  // use buffer, pay attention!
  int bufindex = 0; // reset buffer
  int loadindex = 0; // reset load
  int contentLength = 0; // reset POST content length
  char compare[50]; // page comparison (URI selection)
  HTTP_DEF http_def; // use the structure for multiple returns
  http_def.pages = 0; // default page selection... error
  // reading all rows of header
  if (client.connected() && client.available()) { // read a row
    buffer[0] = client.read();
    buffer[1] = client.read();
    bufindex = 2;
    // read the first line to determinate the request page
    while (buffer[bufindex-2] != '\r' && buffer[bufindex-1] != '\n') { // read full row and save it in buffer
      c = client.read();
      if (bufindex<STRING_BUFFER_SIZE) buffer[bufindex] = c;
      bufindex++;
    // select the page from the buffer (GET and POST) [start]
    for(i = 0; i < NUM_PAGES; i++) {
      strcpy_P(load, (char*)pgm_read_word(&(http_uris[i])));
      // GET
      strcpy(compare,"GET ");
      strcat(compare,load);
      strcat(compare," ");
      Serial.print("GET compare: "); // DEBUG
      Serial.println(compare); // DEBUG
      if (strncmp(buffer,compare, strlen(load)+5)==0) {
        http_def.pages = i+1;
      // POST
      strcpy(compare,"POST ");
      Serial.print("POST compare: "); // DEBUG
      if (strncmp(buffer,compare, strlen(load)+6)==0) {
    // select the page from the buffer (GET and POST) [stop]
    // read other stuff (for POST requests) [start]
    if (strncmp(buffer, "POST /", 5)==0) {
      processRequest:
      loadindex = 2; // reset load
      memset(load,0,STRING_LOAD_SIZE);
      load[0] = client.read();
      load[1] = client.read();
      while (load[loadindex-2] != '\r' && load[loadindex-1] != '\n') {
        c = client.read();
        if (loadindex<STRING_BUFFER_SIZE) load[loadindex] = c;
        loadindex++;
      if (strncmp(load, "Content-Length: ",16)==0) {
        loadindex = 16;
        for(i = loadindex; i< strlen(load) ; i++) {
          if (load[i] != ' ' && load[i] != '\r' && load[i] != '\n') {
            vars[i-loadindex] = load[i];
        contentLength = atoi(vars);
        memset(vars,0,STRING_VARS_SIZE);
        client.read(); client.read(); // read null line
        i = 0;
        while (i<contentLength) {
          c = client.read();
          vars[i] = c;
          ++i;
      	goto processRequest;
    // read other stuff (for POST requests) [stop]
    // clean buffer for next row
    bufindex = 0;
//      delay(10); // removing this nothing work... if you understand why mail me a bebbo [at] bebbo [dot] it
  Serial.print("Grepped page: "); // DEBUG
  Serial.println(http_def.pages); // DEBUG
  strncpy(http_def.vars,vars,STRING_VARS_SIZE);
  return http_def;
*                                                              Send Pages
void sendPage(EthernetClient client,struct HTTP_DEF http_def) {
  // send HTML header
  // contentPrinter(client,(char*)pgm_read_word(&(contents_main[CONT_HEADER])));
  contentPrinter(client,(char*)pgm_read_word(&(contents_main[CONT_TOP])));
  // send menu
  contentPrinter(client,(char*)pgm_read_word(&(contents_main[CONT_MENU])));
  // send title
  contentPrinter(client,(char*)pgm_read_word(&(contents_titles[http_def.pages-1])));
  // send the body for the requested page
  sendContent(client,http_def.pages-1);
  client.print("
  // send POST variables
  client.print(vars);
  // send footer
  contentPrinter(client,(char*)pgm_read_word(&(contents_main[CONT_FOOTER])));
*                                                              Send content split by buffer size
void contentPrinter(EthernetClient client, char *realword) {
  int total = 0;
  int start = 0;
  int realLen = strlen_P(realword);
  memset(buffer,0,STRING_BUFFER_SIZE);
  while (total <= realLen) {
    // print content
    strncpy_P(buffer, realword+start, STRING_BUFFER_SIZE-1);
    client.print(buffer);
    // more content to print?
    total = start + STRING_BUFFER_SIZE-1;
    start = start + STRING_BUFFER_SIZE-1;
*                                                              Send real page content
void sendContent(EthernetClient client, int pageId) {
  contentPrinter(client,(char*)pgm_read_word(&(contents_pages[pageId])));
*                                                          END OF CODE! WELL DONE!
Sorry for the mass of text.
I'm trying to get the 1st page to display these results:
 delay(11600000);
  Serial.print("Getting temperatures...\n\r");
  sensors.requestTemperatures();
  Serial.print("Coolroom: "); // coolroom
  printTemperature(insideThermometer);
  Serial.print("\n\r");
    Serial.print("Salad Fridge: "); //Salad Fridge
  printTemperature(outsideThermometer);
  Serial.print("Dairy Fridge: "); //Dairy Fridge
  printTemperature(dogHouseThermometer);
  Serial.print("Freezer: "); //Freezer
  printTemperature(Freezer);
  Serial.print("\n\r\n\r");
The part I'm trying to insert it into:
I'm hoping it's a simple little bit that's confusing me.
Thanks in advance for any help!
The DallasTemperature library example is crap. The printTemperature() function does not print the temperature. It gets and prints the temperature. It does not store the temperature anywhere so that other functions can access it.
You can attach code, using the Additional Options link below the gray text entry box. That is a much better option than multiple posts of snippets of code.
I'll attach the file next time.
Thanks for the help, I'll research other methods of getting the temp other than dallas. Are there any easy ones that work with one wire temp probes?
There is nothing wrong with the dallas library, other than the crappy example. Change the printTemperature() method name to getTemperature(), remove the code from the function that prints the value to the serial port, and make the function return a value, and the function is even a good function.
That functions really should be called getPrintAndDiscardTemperature(). Then, I'd be OK with it, since that is what the function actually does. It just has a crappy name. Remove the PrintAndDiscard functionality, and it would be a properly named, and useful, function.
Awesome.
Thanks heaps for the advice. You've given me something to work with. I understand why it wasn't working now, thanks again for the help!
