I am trying to create an IoT broadcast lamp project, which has main features:
REAL-TIME MUSIC SYNCHRONIZATION
Creating lighting effects that harmonize with the music being played
BROADCAST CONTENT ADAPTATION
This lamp connects to broadcast platforms via Internet connection USER PERSONALIZATION
Can set color preferences and lighting patterns
AESTHETIC DESIGN
This Broadcast Lamp is not just a technology device but also a decorative element that beautifies the space
I am encountering issues with installing the MSGEQ7. I have already used GPT and Grok and searched for sources on the internet, but they all provide different results. I want to try everything but I'm afraid of damaging the MSGEQ7. Is there anyone here who can help?
Hi
Using a MSGEQ7 is a quite easy, the datasheet has a detail explanation of the protocol.
The main issue are the chips itself. There are many fake or damaged MSGEQ7 on the Ali and Amazon.
Try to NOT use AI, it's not reliable and will not teach you. Books are for learning, YT for eye candy, AI for nothing.
Your project is very doable for a new person.
I don't know where IOT fits-in but note that the MSGEQ7 requires an analog signal.
P.S.
I've made several sound activated lighting effects but nothing with the MSGEQ7 or any frequency analysis.
But just to get you off-the-ground, take a look at my World's Simplest Lighting Effect.. It also takes an analog input which can be a line-level or headphone-level signal, or you can use a "sound sensor" microphone board.
