Help with integers
I just picked up a Arduino starter kit and completed some of the project in the book.
I wanted to try something for myself, but am a bit stuck on the code.
Here is what I want to do :
I have 3 buttons and 3 LED (1 green (pin 3) and two red ones (pin 4,5)
the buttons are on pins 8,9,10.
I put in a code so the two red LED blink as long as the buttons are nog pushed a certain amount of times.
In this example this is 3x button 1, 2x button 2 and 4x button 3.
When this is completed the green LED should light up.
For some reason, the green LED doesn’t light up.
I think the variables I have declared (Code1, Code2, Code3) don’t count up the number of times I push the button.
Can anyone point me in the right direction?
Thanks in advance
int switchState1 = 0;
int switchState2 = 0;
int switchState3 = 0;
int Code1 = 0;
int Code2 = 0;
int Code3 = 0;
void setup(){
  pinMode(3,OUTPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(8,INPUT);
  pinMode(9,INPUT);
  pinMode(10,INPUT);
void loop(){
  switchState1 = digitalRead(8);
  switchState2 = digitalRead(9);
  switchState3 = digitalRead(10);
if ((Code1 == 3) && (Code2 == 2) && (Code3 == 4)) {
  digitalWrite(3,HIGH);
else if (switchState1 == HIGH) {
  Code1 = Code1 + 1;
else if (switchState2 == HIGH) {
  Code2 = Code2 + 1;
else if (switchState3 == HIGH) {
  Code3 = Code3 + 1;
else {
  digitalWrite(3, LOW);
  digitalWrite(4, LOW);
  digitalWrite(5, HIGH);
  delay(100);
  digitalWrite(4, HIGH);
  digitalWrite(5, LOW);
  delay(100);
Consider how fast “loop()” runs.
You need to detect the transition from “not pushed” to “pushed”, not “is the button pushed”.
Check the examples in the IDE.
