Hi, I am trying to generate a sine wave with the arduino, and a digital-to-analog converter. I have most of the code and hardware all setup, but I want to make this device have variable frequency, but I am not sure if this code allows for this.
Essentially, I want to be able to alter the value of TCNT2 in the ISR(TIMER2_OVF_vect) function. I want to be able to pass in a value for it from elsewhere, but this does not seem like the most straightforward process.
Is there any way that I could do this?
Copyright 2007 Richard Cappels used with his permission
www.projects.cappels.org
This assumes an R/2R DAC (or other DAC) connected to PORTD, and
Arduino 16mhz clock
The frequency measured at the output of the DAC is 1.007 kHz.
ported to arduino by hotcarrier
output to pd7-pd2 with 6 bits- needs high order pd7 to work
correctly
#include <avr/interrupt.h>
#include <stdlib.h>
char sinetable [32];
int i ;
int b = 0;
void ioinit (void)
//Initialize output ports
PORTD = B11111111;
DDRD = B11111111;
void timer_setup(){
TCCR2A = 0;
TCNT2= 0; //455 outputs 1.007khz
TCCR2B = B00000010;
//Timer2 Overflow Interrupt Enable
TIMSK2 = 1<<TOIE2;
void setup(){
ioinit();
arraysetup();
cli();
timer_setup();
i = 0;
sei();
ISR(TIMER2_OVF_vect) {
PORTD=(sinetable[i++]);
TCNT2=455;
if(i==32){
i=0;
void arraysetup(void){
sinetable[0]=127; // Put 32 step 8 bit sine table into array.
sinetable[1]=152;
sinetable[2]=176;
sinetable[3]=198;
sinetable[4]=217;
sinetable[5]=233;
sinetable[6]=245;
sinetable[7]=252;
sinetable[8]=254;
sinetable[9]=252;
sinetable[10]=245;
sinetable[11]=233;
sinetable[12]=217;
sinetable[13]=198;
sinetable[14]=176;
sinetable[15]=152;
sinetable[16]=128;
sinetable[17]=103;
sinetable[18]=79;
sinetable[19]=57;
sinetable[20]=38;
sinetable[21]=22;
sinetable[22]=10;
sinetable[23]=3;
sinetable[24]=0;
sinetable[25]=3;
sinetable[26]=10;
sinetable[27]=22;
sinetable[28]=38;
sinetable[29]=57;
sinetable[30]=79;
sinetable[31]=103;
while (1)
