Help with IoT water flow monitoring schematic
No.
  1. The C1 connection makes no sense at all, and should go from VO to GND. F1 is not needed. From the regulator data sheet:
  1. The circuit appears to connect a 5V sensor output with a 3.3V input. A logic level shifter is required. A 1K;2K resistor divider will work. Perhaps the flow sensor will work on 3.3V, in which case drop the boost converter.
