I took an IR receiver out of an old VCR and I'm trying to get it to work with my Arduino.
I'm using this code:
* File....... IRanalyzer.pde
* Purpose.... Records up to 128 signal changes
* Author..... Walter Anderson
* E-mail..... wandrson@walteranderson.us
* Started.... 18 May 2007
* Updated.... 18 May 2007
#include <avr/interrupt.h>
#include <avr/io.h>
#define TIMER_RESET TCNT1 = 0
#define SAMPLE_SIZE 64
int IRpin = 2;
unsigned int TimerValue[SAMPLE_SIZE];
char direction[SAMPLE_SIZE];
byte change_count;
long time;
Serial.println("Analyze IR Remote");
TCCR1A = 0x00; // COM1A1=0, COM1A0=0 => Disconnect Pin OC1 from Timer/Counter 1 -- PWM11=0,PWM10=0 => PWM Operation disabled
// ICNC1=0 => Capture Noise Canceler disabled -- ICES1=0 => Input Capture Edge Select (not used) -- CTC1=0 => Clear Timer/Counter 1 on Compare/Match
// CS12=0 CS11=1 CS10=1 => Set prescaler to clock/64
TCCR1B = 0x03; // 16MHz clock with prescaler means TCNT1 increments every 4uS
// ICIE1=0 => Timer/Counter 1, Input Capture Interrupt Enable -- OCIE1A=0 => Output Compare A Match Interrupt Enable -- OCIE1B=0 => Output Compare B Match Interrupt Enable
// TOIE1=0 => Timer 1 Overflow Interrupt Enable
TIMSK1 = 0x00;
pinMode(IRpin, INPUT);
Serial.println("Waiting...");
change_count = 0;
while(digitalRead(IRpin) == HIGH) {}
TIMER_RESET;
TimerValue[change_count] = TCNT1;
direction[change_count++] = '0';
while (change_count < SAMPLE_SIZE) {
if (direction[change_count-1] == '0') {
while(digitalRead(IRpin) == LOW) {}
direction[change_count++] = '1';
Serial.println("Bit stream detected!");
change_count = 0;
time = (long) TimerValue[change_count] * 4;
Serial.print(time);
Serial.print("\t");
Serial.println(direction[change_count++]);
Serial.print(time);
Serial.print("\t");
Serial.println(direction[change_count-1]);
Serial.print(time);
Serial.print("\t");
Serial.println("Bit stream end!");
delay(2000);
The board and see the "count" or whatever it is when a button is pressed, but If I press the same key multiple times I get different numbers every time. I have the receiver decoupled with a 150 ohm resistor inline with the power on the receiver and a 10uF capacitor across power and ground.
Any Idea what's going on? The binary digits it gives me are the same across remotes/buttons but the time column is the one that changes.
