Help with keypadtest.pde listed in the Keypad Tutorial
/* Keypadtest.pde
  • Demonstrates the simplest use of the keypad library.
    #include <Keypad.h>
const byte ROWS = 4; // 4 rows
const byte COLS = 3; // 3 columns
// Define the Keymap
char keys [ROWS][COLS] = {
{‘1’,‘2’,‘3’},
{‘4’,‘5’,‘6’},
{‘7’,‘8’,‘9’},
{’’,‘0’,’#’}
Connect keypad pin 2 (ROW0) to Arduino pin 9
7 (ROW1) pin 8
6 (ROW2) pin 7
4 (ROW3) pin 6
3 (COL0) pin 12
1 (COL1) pin 11
5 (COL2) pin 10
byte rowPins[ROWS] = {9,8,7,6};
byte colPins[COLS] = {12,11,10};
// Create the keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
#define ledpin 13
digitalWrite(ledpin, HIGH);
char key = kpd.getkey();
// During Verify the previous line produces the error " ‘CLASS KEYPAD’ HAS NO MEMBER NAMED ‘GETKEY’
// What is the remedy?
if(key) //Check for a valid key
switch (key)
case ‘*’:
digitalWrite(ledpin, LOW);
case ‘#’:
digitalWrite(ledpin,HIGH);
default:
Serial.println(key);
// During Verify the previous line produces the error " 'CLASS KEYPAD' HAS NO MEMBER NAMED 'GETKEY'
When using the Arduino software you are actually using C, C++ which is case sensitive. The function you need is kdp.getKey() with a capital K which is different from kpd.getkey() which truly does not exist.
-Mark
