Help with Kinetic Art Project
Gentlemen, It's the never ending story of us asking questions and not giving enough info, so you guys have to guess. Sorry but it's only to avoid long threads.
As to where I am, Pls see:
@PaulRB Cogs were my first choice. All the shafts go through the frame.
I have some problems. My gears were not CNC'd but 3D printed and are not fine like the original one, so they have a little "play". The white parts of the gears were printed separately, as a half circle, and I had to glue them to the black gears, thus loosing some precision. After a lot of trials and throwing away gears and frames (life is hard for rookies) I found out that the gears can not be aligned in a strait line in order to turn. They kept getting stuck.
My panel works, i.e. it turns , but as you can see in the video is not precise.
So, I thought why all the trouble ? I'll just 3D print the white half circle ( the back ground is black anyway) stick them to a motor, and turn them. Then make a full disc in the back of each to place a magnet for the sensor.
Hope you have the whole picture now. Thank you all
