Help with Kinetic Art Project
Leo, it's only my fault and not your's. I'm still in debt to you for your help and kindness. As you can see in the photos I connected everything as your instructions. Here's your code I'm using :
 Nano | TPIC6B595
   5V | 2 (VCC)
  GND | GND
   D8 | 8 (SRCLR)
  D10 | 12 (RCK)
  D11 | 3 (SER IN) of the first chip
  D13 | 13 (SRCK)
      | 9 to GND
      | 10, 11,19 to GND
      | 18 (SER OUT) to 3 of the next chip
#include <SPI.h>
const byte motors = 48; // sets of four motors
const byte clrPin = 8; // TPIC6B595 SRCLR pin8
const byte latchPin = 10; // TPIC6B595 RCK pin12
const byte rampSteps = 7; // accel/decel steps
byte rampDelay[motors]; // accel/decel delay between steps
byte lag[motors]; // speed reduction
int velocity[motors]; // signed, for direction
int nowPos[motors], newPos[motors]; // int is 16 rotations max (2.5m string with a 50mm dia wheel)
unsigned long prevMillis, prevMicros, interval; // timing
byte val[4]; // TPIC write bytes
bool torque; // reduced during homing
byte sequence, index; // patterns, motor index
 SPI.begin();
 pinMode(clrPin, OUTPUT);
 pinMode(latchPin, OUTPUT);
 digitalWrite(clrPin, HIGH); // clear all shift register data
 for (byte i = 0; i < motors; i++) nowPos[i] = 1024; // homing all motors 1/2 turn
 switch (sequence) {
   case 0: // break free from the top, all motors
     if (nowPos[0] == newPos[0]) { // finished homing
       for (byte i = 0; i < motors; i++) nowPos[i] = -128; // 1/16 turn
       torque = true; // was low power during homing
       sequence = 1; // case 0 is not called anymore
       prevMillis = millis(); // so mark here
     break;
   case 1: // 4.5 turns down, all motors
     if (millis() - prevMillis > 8000) {
       for (byte i = 0; i < motors; i++) newPos[i] = 9216; // 4.5 * 2048
       sequence = 2;
     break;
   case 2: // all return to zero, one after the other
     if (millis() - prevMillis > 30000 + interval) {
       if (index < motors) {
         newPos[index] = 0;
         interval += 500;
         index += 1;
       } else { // when done
         index = 0;
         interval = 0;
         sequence = 3;
     break;
   case 3: // run sequence(s) again
     if (millis() - prevMillis > 75000) {
       sequence = 1;
     break;
