Help with LED Bar Graph and 4017 without Delay
I am currently trying to control an LED bargraph using a 4017 decade counter as in this example:
My question is how would I do this without using delay? I have looked at the BlinkwithoutDelay code and this was my attempt, however it does not work. Any help is appreciated!
 * LED Bar Graph controlled with an external potentiometer.
 * A 4017 counter is used to save pins on the arduino.
 * The technique of "Persistence of vision" is used to turn on
 * many LEDs at the same time.
 * Developed by Leonel Machava
 * http://codentronix.com
 * This code is release under the "MIT License" available at
 * http://www.opensource.org/licenses/mit-license.php
/* Digital pin connected to the counter's clock pin */
int clockPin = 7;
/* Digital pin connected to the counter's reset pin */
int resetPin = 6;
/* Analog pin connected to the potentiometer wiper */
int potPin = 0;
long clockTimer = 0;
long resetTimer = 0;
int clockState = LOW;
int resetState = LOW;
  pinMode(clockPin,OUTPUT);
  pinMode(resetPin,OUTPUT);
  digitalWrite(resetPin,HIGH);
  delay(1);
  digitalWrite(resetPin,LOW);
  /* Read the analog value from the potentiometer. */
  int potValue = analogRead(potPin);
  /* Map the value to the range 0-9. */
  int n = potValue * 10 / 1024;
  /* Turn ON/OFF quickly the first n LEDs. The n LEDs
     will appear to be ON at the same time due to the
     "persistence of vision" effect. */
  long currentMillis = millis();
  if(currentMillis - clockTimer > 100) {
    clockTimer = currentMillis;
    for( int i = 0; i < n; i++ ) {
      if (clockState == HIGH) {
        clockState = LOW;
      else {
        clockState = HIGH;
      digitalWrite(clockPin, clockState);
  if(currentMillis - resetTimer > 100) {
    resetTimer = currentMillis;
    if (resetState == HIGH) {
      resetState = LOW;
    else {
      resetState = HIGH;
    digitalWrite(resetPin, resetState);
The code in the link you supply uses delay() to settle the 4017. You can probably replace that delay with delaymicroseconds() to make it faster. You actually need to leave it on for a short interval to get the pov effect happening, so I don't think you can remove all delays.
Each time round the loop you are creating a new value of currentMillis and setting it to the current time. Therefore there is no way the if statement that follows it is ever going to be true.
The delay used in the code I posted above was just in the setup. I tried to incorporate the technique used in BlinkwithoutDelay example which was in the loop portion of that code. But I'm not wanting to remove the delay in the display altogether, just do it without using the delay function so that my code can be doing other things at the same time.
