help with LED Button sketch
ok well right now im still bouncing around ideas so i dont have any code written but i want to write up a sketch that will enable me to switch between different modes. in one mode i will be able to press a button and have an LED light up the button with a certain color. in another mode i want to be able to make the LED change colors so that the button seems to be changing colors. i want to be able to hold down a button or two for a certain amount of time so that the arduino knows that i want to switch modes but i dont know how i would write that. any help?
You could use PulseIn command. http://arduino.cc/en/Reference/PulseIn
Or multiple If sentences. As far as LED goes use an RBG LED.
Start at the beginning; look at some of the examples of how to fade a single LED. Look at how to accept button presses, then merge.
I know all of these basic things already but what i want to be able to do is just change the mode at any given time and not just at start up so how would i loop that?
You would put your code in “loop”.
Why don’t you show us your code, and we can help you from there.
