Hello,
I have been testing a 3x3x3 LED Cube. I tried to make programming sequences easier by creating a couple Libraries.
Frame.h
Michael B
8/13/2011
LED Cube Programming Test
controls 3x3x3 cube by assigning each LED a number
#ifndef Frames
#define Frames
#include "WProgram.h"
class Frame{
private:
//variables
bool toggled;
unsigned int count;
int LED[27];
int pixelSize;
bool lastFrame;
int C[9];
int A[3];
//private member functions
void On(int led);
void Off(int led);
public:
//public member functions
Frame();
Frame(int led[], int size);
void setLED(int led[], int size);
void frameCycle();
int getSize();
#endif
Frame.cpp
Michael B
8/13/2011
#include "Frame.h"
const int LAYER = 9;
Frame::Frame(){
for(int i = 0; i < 27; i++){
LED[i] = 0;
pixelSize = 0;
toggled = false;
count = 0;
lastFrame = false;
for(int i = 0; i < 9; i++){
C[i] = i+2;
for(int i = 0; i < 3; i++){
A[i] = i+11;
Frame::Frame(int led[], int size = 0){
LED[i] = led[i];
pixelSize = size;
toggled = false;
count = 0;
lastFrame = false;
C[i] = i+2;
A[i] = i+11;
void Frame::setLED(int led[], int size){
LED[i] = led[i];
pixelSize = size;
void Frame::frameCycle(){
//checks to see if the led is on or off
if (toggled == false){
//turns it on
On(LED[count]);
toggled = true;
}else{
//turns it off
Off(LED[count]);
toggled = false;
//increase for next LED pixel in frame
count++;
if(count >= pixelSize){
count = 0;
void Frame::On(int led){
int Anode = 0;
int Cathode = 0;
//figures out which anode and cathode to switch for
//the LED number given
Anode = (int) led / LAYER;
Cathode = (int) led % LAYER;
//LED on
digitalWrite(A[Anode], 1);
digitalWrite(C[Cathode], 0);
void Frame::Off(int led){
int Anode = 0;
int Cathode = 0;
//LED off
digitalWrite(A[Anode], 0);
digitalWrite(C[Cathode], 1);
int Frame::getSize(){
return pixelSize;
Sequence.h
Michael B
8/13/2011
#ifndef Sequences
#define Sequences
#include "Frame.h"
class Sequence{
private:
Frame frames[15];
int frameSize;
int delaySize;
int frameCount;
int delayCount;
int toggleCount;
int toggleMAX;
public:
Sequence(int size);
void set(Frame frameList[], int size, int delay);
void setFrameSize(int size);
void setDelaySize(int size);
void addFrame(Frame frame);
void sequenceCycle();
#endif
Sequence.cpp
Michael B
8/13/2011
#include "Sequence.h"
Sequence::Sequence(int size){
frameSize = size;
delaySize = 0;
frameCount = 0;
delayCount = 0;
toggleCount = 1;
toggleMAX = 2;
void Sequence::set(Frame frameList[], int size, int delay){
for(int i = 0; i < size; i++){
frames[i] = frameList[i];
frameSize = size;
delaySize = delay;
frameCount = 0;
delayCount = 0;
toggleCount = 1;
toggleMAX = 2;
void Sequence::setFrameSize(int size){
frameSize = size;
void Sequence::setDelaySize(int size){
delaySize = size;
void Sequence::addFrame(Frame frame){
frames[frameSize] = frame;
frameSize++;
void Sequence::sequenceCycle(){
//call frame cycle
frames[frameCount].frameCycle();
//increase count, which delays the frame from switching
delayCount++;
if(delayCount > delaySize){
//reset delay count
delayCount = 0;
//increase a two count variable
//The logic is that i need the same frame cycle to be called twice
//before switching to the next frame
//One cycle turns the LEDs on
//One cycle turns the LEDs off
toggleCount++;
if(toggleCount > toggleMAX){
//increase to next frame
frameCount++;
toggleCount = 1;
//reset to beginning frame
if(frameCount > frameSize - 1){
frameCount = 0;
Michael B
8/13/2011
#include <avr/pgmspace.h>
//Sequence of frames
#include <Sequence.h>
//Set of pixels(individual LEDs)
#include <Frame.h>
//Timer1 Library from www.Arduino.com
#include <TimerOne.h>
//Anode and Cathode pins
int C[9] = {2,3,4,5,6,7,8,9,10};
int A[3] = {11,12,13};
//set up pixel arrays
int Square1[4][16] = {
//{0,1,2,3,4,5,6,7,8,0,0,0,0,0,0,9},
//{9,10,11,12,13,14,15,16,17,0,0,0,0,0,0,9},
//{18,19,20,21,22,23,24,25,26,0,0,0,0,0,0,9},
//{6,7,8,15,16,17,24,25,26,0,0,0,0,0,0,9},
//{3,4,5,12,13,14,21,22,23,0,0,0,0,0,0,9},
{0,1,2,9,10,11,18,19,20,0,0,0,0,0,0,9},
{2,5,6,7,8,11,14,15,16,17,20,23,24,25,26,15},
{1,3,4,5,7,10,12,13,14,16,19,21,22,23,25,15},
{0,1,2,3,6,9,10,11,12,15,18,19,20,21,24,15}
//initialize 9 frames
Frame v[4];
//initialize sequence of frames
Sequence Test(4);
void setup(){
//set pinouts
//turn off all LEDs
pinMode(C[i], OUTPUT);
digitalWrite(C[i], 1);
pinMode(A[i], OUTPUT);
digitalWrite(A[i], 0);
//add LED arrays to sequence
for(int i = 0; i < 4; i++){
v[i].setLED(Square1[i],Square1[i][15]);
//set up timer 1
Timer1.initialize(500);
Timer1.pwm(9,512);
Timer1.attachInterrupt(trigger);
digitalWrite(9,1);
//setup sequence and delay
Test.set(v,4,400);
void loop(){
//interrupt call
void trigger(){
//sequence cycle call
Test.sequenceCycle();
The idea is that there are pixels in a Frame (as in frames per second), and Frames in a sequence. That way I could have a lot of different Sequences and it would be easy to interchange them. I apologize if the code is hard to read. I am an EE undergrad.
The code compiles and uploads fine. My problem is that when I include more then 4 Frames in a Sequence or include more than one Sequence, my Arduino, freezes i guess. I do not get any response from it.
Am I running out of memory or something? If so, how do I create a lot of sequences on an Arduino for a LED cube?
