Hi, I'm doing debugging through the serial monitor. Arduino Leonardo with 1.5.2
When I upload the sketch, COM11 and COM13 are available, I use COM13, upload, open serial monitor, all is good, data is flowing.
If I use the "reset" button on the Leonardo the COM13 serial monitor remains open, but nothing is coming through.
Also COM13 is no longer available to choose from in the IDE.
I close serial monitor on COM13 and try to open serial monitor again. I get an error in the IDE "Serial port COM13 not found".
I try the only available port, COM11 and open serial monitor, it opens, but no data is coming through.
So, how do I use the serial monitor after a reset on the board? At this stage I can only use Serial Monitor by uploading a sketch each time.
Thanks for your help.
