Help With Library Error - Rev 4 Wifi and Settimino
Hi all, I am brand new to Arduino. I picked up an R4 Wifi Board and a Ethernet Shield 2.
I have been looking into the library Settimino to comms with a Siemens CPU.
I have tried to load all the correct libraries etc to run the sample programs but keep getting errors.
library from https://settimino.sourceforge.net
```cpp
 Read Status Demo
 Created 12 Dec 2016
 Modified 10 Mar 2019 for Settimino 2.0.0
 by Davide Nardella
This demo shows how to read the PLC status.
The model extended is needed.
- During the loop, try to disconnect the ethernet cable.
  The system will report the error and will reconnect automatically
  when you re-plug the cable.
- For safety, this demo *doesn't write* data into the PLC, try
  yourself to change ReadArea with WriteArea.
- This demo uses ConnectTo() with Rack=0 and Slot=2 (S7300)
  - If you want to connect to S71200/S71500 change them to Rack=0, Slot=0.
  - If you want to connect to S7400 see your hardware configuration.
  - If you want to work with a LOGO 0BA7 or S7200 please refer to the
    documentation and change
    Client.ConnectTo(<IP>, <Rack>, <Slot>);
    with the couple
    Client.SetConnectionParams(<IP>, <LocalTSAP>, <Remote TSAP>);
    Client.Connect();
#include "Platform.h"
#include "Settimino.h"
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE11 };
IPAddress Local(192,168,0,90); // Local Address
IPAddress PLC(192,168,0,12);   // PLC Address
// Following constants are needed if you are connecting via WIFI
// The ssid is the name of my WIFI network (the password obviously is wrong)
char ssid[] = "SKYNET-AIR";    // Your network SSID (name)
char pass[] = "yourpassword";  // Your network password (if any)
IPAddress Gateway(192, 168, 0, 1);
IPAddress Subnet(255, 255, 255, 0);
S7Client Client;
unsigned long Elapsed; // To calc the execution time
int LastStatus = -1;   // To force the first print
// Setup : Init Ethernet and Serial port
#ifdef S7WIFI
//--------------------------------------------- ESP8266 Initialization
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, pass);
    WiFi.config(Local, Gateway, Subnet);
    while (WiFi.status() != WL_CONNECTED)
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.print("Local IP address : ");
#else
//--------------------------------Wired Ethernet Shield Initialization
    // Start the Ethernet Library
    EthernetInit(mac, Local);
    // Setup Time, someone said me to leave 2000 because some
    // rubbish compatible boards are a bit deaf.
    delay(2000);
    Serial.println("");
    Serial.println("Cable connected");
    Serial.println(Ethernet.localIP());
#endif
// Connects to the PLC
bool Connect()
    int Result=Client.ConnectTo(PLC,
                                  0,  // Rack (see the doc.)
                                  0); // Slot (see the doc.)
    Serial.print("Connecting to ");Serial.println(PLC);
    if (Result==0)
      Serial.print("Connected ! PDU Length = ");Serial.println(Client.GetPDULength());
      Serial.println("Connection error");
    return Result==0;
// Prints the Error number
void CheckError(int ErrNo)
  Serial.print("Error No. 0x");
  Serial.println(ErrNo, HEX);
  // Checks if it's a Severe Error => we need to disconnect
  if (ErrNo & 0x00FF)
    Serial.println("SEVERE ERROR, disconnecting.");
    Client.Disconnect();
// Profiling routines
void MarkTime()
  Elapsed=millis();
void ShowTime()
  // Calcs the time
  Elapsed=millis()-Elapsed;
  Serial.print("Job time (ms) : ");
  Serial.println(Elapsed);
// Main Loop
  int Result, Status;
  // Connection
  while (!Client.Connected)
    if (!Connect())
  MarkTime();
  Result = Client.GetPlcStatus(&Status);
  if (Result==0)
    if (Status!=LastStatus)
      LastStatus=Status;
      Serial.print("CPU Status change detected, now is ");
      switch (Status)
        case S7CpuStatusUnknown:
          Serial.println("UNKNOWN");
        case S7CpuStatusRun:
          Serial.println("RUNNING");
        case S7CpuStatusStop:
          Serial.println("STOPPED");
    CheckError(Result);
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino: In function 'bool Connect()':
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino:93:16: error: reference to 'Client' is ambiguous
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino:48:10: note: candidates are: S7Client Client
 S7Client Client;
In file included from C:\Users\SDJRo\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.5\cores\arduino/api/deprecated/Client.h:23:0,
                 from C:\Users\SDJRo\Documents\Arduino\libraries\Ethernet\src/Ethernet.h:52,
                 from C:\Users\SDJRo\Documents\Arduino\libraries\Settimino/Platform.h:98,
                 from C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino:29:
c:\users\sdjro\appdata\local\arduino15\packages\arduino\hardware\renesas_uno\1.0.5\cores\arduino\api\client.h:27:7: note:                 class arduino::Client
 class Client : public Stream {
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino:99:64: error: reference to 'Client' is ambiguous
 S7Client Client;
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino: In function 'void CheckError(int)':
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino:117:5: error: reference to 'Client' is ambiguous
 S7Client Client;
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino: In function 'void loop()':
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino:143:11: error: reference to 'Client' is ambiguous
 S7Client Client;
C:\Users\SDJRo\AppData\Local\Temp\.arduinoIDE-unsaved202404-10108-az3cmb.j40yi\StatusDemo\StatusDemo.ino:150:12: error: reference to 'Client' is ambiguous
 S7Client Client;
Multiple libraries were found for "WiFi.h"
  Used: C:\Users\SDJRo\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.5\libraries\WiFiS3
  Not used: C:\Users\SDJRo\Documents\Arduino\libraries\ESP8266WiFi
exit status 1
Compilation error: reference to 'Client' is ambiguous
Any help would be appreciated.
Thank You
Please edit your post and put the error message in code tags to make it easier to read and copy
Please post your sketch, using code tags when you do
Sorry about that, should be in a better format now.
The error message in code tags is better but the picture of your code is not. Copy the code from the IDE and post it here using code tags as requested.
"Edit/Copy for Forum" in the IDE will even add the code tags for you
3rd times the charm haha, sorry about that.
