Help with LM34 Temperature Sensor
Hello! I am trying to display temperature and change fan speed based on the temperature read. I am following a tutorial from Science Fun on youtube. The code is as follows:
float temperature;
const int fan_control_pin = 3;
int count = 0;
unsigned long start_time;
int rpm;
pinMode(fan_control_pin, OUTPUT);
analogWrite(fan_control_pin, 0);
attachInterrupt(digitalPinToInterrupt(2), counter, RISING);
temperature = float(analogRead(A10)) * 500.0 / 1024.0;
if (temperature < 100.0) analogWrite(fan_control_pin, 0);
if ((temperature >= 100.0) && (temperature < 120.0)) analogWrite(fan_control_pin, 126);
if (temperature >= 120.0) analogWrite(fan_control_pin, 255);
start_time = millis();
count = 0;
while((millis() - start_time) < 1000){
rpm = count * 60 / 2;
Serial.print("The temperature is ");
Serial.print(temperature);
Serial.print((char)176);
Serial.println("F");
Serial.print("The fan speed is ");
Serial.print(rpm);
Serial.println(" rpm");
void counter() {
count++;
The problem is that it is not displaying the correct temperature on the terminal. I believe I have it wired correctly, it is a simple circuit and I had it checked over. Also, I have swapped the temperature sensors to make sure I am not using broken parts.
I am using an Arduino Due and analog pin A10 because my other pins are being used right now for a larger project.
Here is the terminal output:
Any help will be appreciated, thank you.
Pretty sure you wanna be looking at A0, not A10.
HTH
a7
Hello spancari01
Add some function descriptive comments to the sketch for better understanding of the coding.
Is '176' supposed to be a "degree sign" ?
Not supported.
Does it matter which analog input I use? I figured since they are all analog inputs they would be the same but I could be wrong. I am connecting multiple sensors to this Arduino so if the A0 is already taken what should I do?
Yes sorry, forgot to change that
  1. 500.00 is for a 5volt processor, and you're using a 3.3volt-logic Due. Try 330.0
  2. analogRead returns an int, not a float. Remove 'float' from that line.
  3. readout of an LM34 with default Aref also depends on MCU supply. The tutorial/code does not compensate for that.
    Leo..
I believe the LM34 needs a minimum 5V supply.
https://www.ti.com/lit/ds/symlink/lm34.pdf
Sry, didn't pay attention!
a7
No problem! Thanks for the help
Thank you, I will try this soon.
But should I do 330 is I am supplying 5V to the sensor, not 3.3V or should I change it to supply 3.3V?
Minimum supply voltage of the LM34 is 4volt, so you should power it from 5volt.
You still can connect it's output to a 3.3volt-logic analogue pin of the Due,
because the sensor will normally output a voltage much lower than 3.3volt.
e.g. ~1volt at body temp (37C,100F).
330 (330.0 actually) is for calculating the temp (with 3.3volt default Aref of a 3.3volt processor).
1024 in that line is for the default 10-bit A/D of the Due.
Leo..
