Help with LM35 fan I2C LCD project
Yes, if I run a code where it detects the temperature only it works fine, if I power on the circuit (with the fan and everything) with only a USB it also works fine- issue being that since its only 5V its not powering on fully. The main issue starts after i plug in the DC power adapter to power on the fan fully.
Also I added in a 1k Ohm resistor to the output of the LM35 in case it might work and added some more stuff into the code :
//  LCD Setup
LiquidCrystal_I2C lcd(0x27, 16, 2);  //address is 0x27
// Pin Definitions
const byte sampleBin = 8;
const int tempPin = A0;     // LM35 out
const int fanPin = 9;       //  PWM control
const int ledPin = 6;       // LED
// Calibration Constants
const int8_t fudge = 90;      // Adjust this for calibration (±5~10 usually fine)
const int kAref = 1090;       // Analog reference voltage in mV (1.1V = 1100mV)
const int kSampleBin = sampleBin * 1000;
//  Temperature&Controlvars
int tempC, tempF;
int pwm;
bool fanOn = false;
uint32_t temp = 0, start = 0;
const int interval = 500;  // Refresh rate
  analogReference(INTERNAL);
  analogRead(tempPin);  // Dummy read
  // Pre-fill temp with average of 8 samples
  for (int i = 0; i < sampleBin; i++)
    temp += analogRead(tempPin);
  lcd.init();
  lcd.backlight();
  pinMode(fanPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  if (millis() - start > interval) {
    start = millis();
    //  average of samples
    temp -= (temp / sampleBin);
    // Convert to °C
    tempC = temp * kAref / (kSampleBin + fudge);
    tempF = (tempC * 18 + 3200) / 10;
    // LCD Display
    lcd.setCursor(0, 0);
    lcd.print("Temp: ");
    lcd.print(tempC / 10);
    lcd.print(".");
    lcd.print(tempC % 10);
    lcd.print((char)223);
    lcd.print("C    ");
    // Fan Control with Hysteresis
    if (!fanOn && tempC >= 160) {       // 16.0°C
      fanOn = true;
    } else if (fanOn && tempC <= 140) { // 14.0°C
      fanOn = false;
    pwm = fanOn ? map(tempC, 150, 450, 100, 255) : 0;
    pwm = constrain(pwm, 0, 255);
    analogWrite(fanPin, pwm);
    //  Overheat LED
    digitalWrite(ledPin, tempC > 400 ? HIGH : LOW); // 40.0°C threshold
    // Serial Debug
    Serial.print("ADC: ");
    Serial.print(analogRead(tempPin));
    Serial.print(" | Temp: ");
    Serial.print(tempC / 10);
    Serial.print(".");
    Serial.print(tempC % 10);
    Serial.print(" C | Fan PWM: ");
    Serial.println(pwm);
