hello, I'm a noob and I'm not sure where or how to post. I'm modifying some code for a project I'm doing and I can't figure where to add the loop function for void singleclick() to keep it running. I would like it to run infinitely till i call the next function. other than the repeat issue the code is working more or less ok.
#include <OneButton.h> //we need the OneButton library
OneButton button(A1, true); //attach a button on pin A1 to the library
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
button.at
tachClick(singleclick); // link the function to be called on a singleclick event.
button.attachLongPressStop(longclick); // link the function to be called on a longpress event.
button.attachDoubleClick(doubleclick); // link the function to be called on a doubleclick event.
button.tick(); // check the status of the button
delay(10); // a short wait between checking the button
} // loop
void singleclick(){// what happens when the button is clicked
// fade in from min to max in increments of 5 points:
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue = fadeValue+1) {
// sets the value (range from 0 to 255):
analogWrite(9, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(10);
// fade out from max to min in increments of 5 points:
for (int fadeValue = 255 ; fadeValue >= 0; fadeValue = fadeValue-1) {
delay(10);
analogWrite(10, fadeValue);
delay(10);
delay(10);
// fad// fade in from min to max in increments of 5 points:
analogWrite(11, fadeValue);
delay(10);
delay(10);
void doubleclick() {
digitalWrite(9,HIGH);
digitalWrite(10,HIGH);
digitalWrite(11,HIGH);
digitalWrite(12,HIGH);
void longclick(){
digitalWrite(9,LOW);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
digitalWrite(12,LOW);
ebritt121, welcome to the forum. Thank you for posting the complete code, but could you please enclose it in [CODE] tags? It makes it so much easier for everyone to read.
singleclick is an interrupt service routine or ISR. It will perform it's function and you will resume running from wherever you were when the interrupt took over.
type or#include <OneButton.h> //we need the OneButton library
pinMode(9, OUTPUT);
button.attachClick(singleclick); // link the function to be called on a singleclick event.
} // loop
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
void longclick(){
paste code here
I hope I did it right this time. I'm not quite sure what a interrupt service routine means. I'm still pretty new. but i will definitely look more into it. The code is working for the most part. I'm just struggling with getting the fade effect "singleclick" to repeat in a cycle. it only runs once then stops. I think I'm supposed to add a loop somewhere in that part of the code or some kind of counter. but that's where I'm stuck. I appreciate your fast response and help. Thank you.
An interrupt is a little like it sounds, a signal to the MCU that causes it to interrupt what it is normally and perform a specific interrupt request servicing function.
Generally, interrupt servicing functions should be very short, perhaps just setting a variable that to indicate that an interrupt has been received, that the main program then does something with.
Your singleclick() function has rather a lot going on within it an should probably be part of the main program. You would have a global variable e.g.:
volatile bool singleclickinterrupt = false;
Then in your main loop you might have something like:
if (singleclickinterrupt) then singleclick();
Note the use of the 'volatile' keyword when declaring the variable, and resetting the 'singleclickinterrupt' variable to false immediately after the change has been detected and processed by the singleclick() servicing function. Obviously you can call the variable whatever you like.
The other two functions are probably short enough although there may be other opinions.
I'm sorry for sounding incompetent. I'm very new at all this and am trying to understand. The main program is where I have my void loop, correct? Is this where I would put my volatile statement? Or is it the void setup part. Again I am very sorry. I really am trying to get a hang of this.
sorry for the late reply. I tried adding the code but I think I did something wrong. I get "Compilation error: 'singleclickinterrupt' was not declared in this scope". I tried looking it up but I'm confused on what I'm supposed to do with it. Do I do singleclickinterrupt = singleclick or int singleclickinterrupt under setup? I'm happy to post what I have if it helps.
C:\Users\STRIX\Documents\Arduino\switch2\switch2.ino: In function 'void loop()':
C:\Users\STRIX\Documents\Arduino\switch2\switch2.ino:23:7: error: 'singleclickinterrupt' was not declared in this scope
C:\Users\STRIX\Documents\Arduino\switch2\switch2.ino:23:7: note: suggested alternative: 'singleclick'
singleclick
C:\Users\STRIX\Documents\Arduino\switch2\switch2.ino:23:29: error: 'then' was not declared in this scope
C:\Users\STRIX\Documents\Arduino\switch2\switch2.ino:23:29: note: suggested alternative: 'tan'
tan
C:\Users\STRIX\Documents\Arduino\switch2\switch2.ino:24:3: error: 'singleclickinterrupt' was not declared in this scope
C:\Users\STRIX\Documents\Arduino\switch2\switch2.ino:24:3: note: suggested alternative: 'singleclick'
singleclick
exit status 1
Not at all. We def need to see the error messages. You can post that in code tags, too but it matters a bit less.
But we can't see how you applied the advices, which may haven't been exactly what anyone thought they were telling you to do.
In general, new problems or questions, please post the latest code. Even if you cou,d say I exactly did this and that. Because we are human too and we might not get your this and that just right...
pinMode(9, OUTPUT);
} // loop
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
void longclick(){
And that statement isn't what you want, I don't think.
Interrupts are not beginner-friendly. In this code, singleclick is a function that gets called automatically, asynchronously to anything you are doing in the other code.
The suggestion was, I think, to have singleclick do nothing more than set the flag you've called singleclickinterrupt.
Literally one line of code in the ISR.
Then in your loop, recognize that the flag was set, and call a function that does all the work you want done because the button got pushed. Its body will be most of what singleclick once contained.
So you could… use the flag and keep calling that work function until something else cleared the flag, like having done the work N times or whatever.
I can't just now, but maybe a second press of the button could clear the flag, sounds like what you were going for, on/off control of the operation.
There are ways to do this without the complexity of involving interrupts. I'll check later and post a demo that might help you get back on the noob track. Interrupts have their place; some of us never advertently use them.
I removed the "then which cleared the error. Thank you for the advice. you are right that I want the fist function to repeat X number of times. In this case till I change it. I'm making a bedroom lamp/nightlight if that helps. I want it to have 3 functions rainbow, reading and off.
No worries. I appreciate all your help and patience. I'm still trying to get the first part of my code to loop/repeat. I'm stuck with it running through only once. I'm sure it's something small. I just don't know what.
if the flag is set
put some number N in a variable like nTimes
clear the flag
if nTimes is greater than zero
do whatever you wanna do once
subtract one from nTimes
That's not code. It is pseudocode, a way to talk about code without getting the pesky syntax and stuff exact.
The first if statement see the flag and sets a number to be how any times to do the thing.
The second if statement checks to see if there is any reason to do the thing, and counts the doing down and won't after it counts down to zero meaning it has done the thing N times.
