Help with LoRa 9x programming
Riva:
Maybe the attached code for an Adafruit Feather Lora (AKA Lora32u4) with a BME280 & LDR sensor will help.
I use a different Lora library and it works well for me.
The project is battery powered so sleeps most of the time but every 30 minutes sends data over Lora. I pack the data into a JSON style string so the receiver just forwards the payload onto Node-Red where it gets extracted and used. I opted for this format so I don't need to also reprogram my Lora gateway every time I alter the Feather code/sensors.
jremington:
The following code uses the itoa() function to convert the variable "packetnum" into a human-readable ASCII character array (C-string) and sends it to the receiver.
   char radiopacket[10] = {0};
itoa(packetnum, radiopacket, 10);
   rf95.send((uint8_t *)radiopacket, strlen(radiopacket));
You can do the same for several integer variables, separated by commas, using [the snprintf() function](http://www.cplusplus.com/reference/cstdio/snprintf/). For example:
char radiopacket[30] = {0}; //make sure this is large enough
   snprintf(radiopacket,sizeof(radiopacket),"%d,%d,%d",pressure, humidity, temperature); //assuming p,h,t are integers
Hey i have been trying out this code and this is what i came up with
#include <LoRa.h>
#include <Adafruit_SleepyDog.h>
#include <Adafruit_BME280.h>
#include <Wire.h>
#include <Adafruit_MPL3115A2.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <RH_RF95.h>
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 2
#define RF95_FREQ 433.0
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME680 bme;
RH_RF95 rf95(RFM95_CS, RFM95_INT);
uint8_t pktNumber = 0;
float temperature;
float pressure;
float altitude;
float humidity;
// OCCAL Tuning value. Calculated from expected 30 minutes actually taking about 33.5 minutes
#define ocCAL 900
const uint32_t delayRead = 10UL * 1 * ocCAL;               // Delay time between reads (10 min)
const uint32_t delaySend = 10UL * 1 * ocCAL;               // Delay time between sends (30 Mins)
uint32_t lastReading = delayRead;                           // Time last reading taken (Set to delayRead so reading happens straight away)
uint32_t lastSending = delaySend;                           // Time last send happened (Set to delaySend so sending happens straight away)
uint32_t sudoMillis = 0;
bool BME680Setup()
  bool status = bme.begin();
  if (!bme.begin()) {
    Serial.println("Could not find a valid BME680 sensor, check wiring!");
    while (1);
    bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
void readBME680()                                           // Get BME280 readings
  BME680Setup();
  // Start with temperature, as that data is needed for accurate compensation.
  // Reading the temperature updates the compensat ors of the other functions in the background.
  temperature = bme.temperature;
  delay(10);
  pressure = bme.pressure / 100.0;
  delay(10);
  altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
  delay(10);
  humidity = bme.humidity;
  delay(10);
void sendResults2(Stream& XXX, bool lora = false)           // Send readings to Stream
  if(lora)
    LoRa.beginPacket();
  XXX.print("{");
  XXX.print("@N@:");
  XXX.print(pktNumber);
  XXX.print(",");
  delay(1);
  XXX.print("@T@:");
  XXX.print(temperature, 2);
  XXX.print(",");
  delay(1);
  XXX.print("@P@:");
  XXX.print(pressure, 2);
  XXX.print(",");
  delay(1);
  XXX.print("@A@:");
  XXX.print(altitude, 2);
  XXX.print(",");
  delay(1);
  XXX.print("@H@:");
  XXX.print(humidity, 2);
  XXX.print(",");
  delay(1);
  XXX.print("}");
  delay(1);
  if(lora)
    LoRa.endPacket();
    pktNumber++;
void errLoop()
  while(1)
    Watchdog.sleep();
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
//#ifdef DEBUG
    //while (!Serial);                                        //  Wait for Serial Port Connection (Remove in final code)
//  #endif
  delay(10);
  Serial.println("Arduino LoRa TX Test!");
//  LoRa.setPins(SS,RST,DI0);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    while (1);
    Serial.println("LoRa radio init OK!");
  LoRa.setPreambleLength(20);
  LoRa.enableCrc();
    if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
 Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  BME680Setup();
  // Take initial readings to prime the rolling averages
  temperature = bme.readTemperature();
  delay(10);
  pressure = bme.readPressure() / 100.0F;
  delay(10);
  delay(10);
  humidity = bme.readHumidity();
  rf95.setTxPower(23, false);
//  #ifdef DEBUG
//    sendResults2(Serial);
//  #endif
  Serial.println(F("\nInitial OK!"));
  sudoMillis = millis();
//  #ifdef DEBUG
    uint32_t now = sudoMillis;
    while(sudoMillis - now < 10)
        bme.performReading();   // Do the readings
        #ifdef DEBUG
          Serial.print(F("\nForce Sending Values: "));
          Serial.println();
        #endif
        sendResults2(LoRa, true);
      delay(10);
      sudoMillis += 10;
  if(sudoMillis - lastReading > delayRead)
    #ifdef DEBUG
      Serial.print(F("\nReading Values: "));
    #endif
    lastReading = sudoMillis;
    #ifdef DEBUG
    #endif
  if(sudoMillis - lastSending > delaySend)                  // Time to send readings via LoRa
    #ifdef DEBUG
      Serial.print(F("\nSending Values: "));
      Serial.println();
    #endif
    lastSending = sudoMillis;
    //sendResults2(LoRa, true);
//    LoRa.sleep();                                           // Power down radio
But this is not working at all, not even getting the setup done so what is wrong/how should i fix it. And is it possible to send data via LoRas that are not integers, lets say for more accurate sensor readings,/gps cordinates.?
