Hi I am using the standard test of the LPD8806.h coding and would like to be able to make the lights go in reverse.
in groups of 8 LEDs at a time. but have them continuously have the LED train running with a gap between the trains of 24 LED's
the LED strip has 80 LED's on it.
can anyone help me on his for I am having trouble understanding the code.
#include "LPD8806.h"
#include "SPI.h"
// Example to control LPD8806-based RGB LED Modules in a strip
// Number of RGB LEDs in strand:
int nLEDs = 80;
// Chose 2 pins for output; can be any valid output pins:
int dataPin = 2;
int clockPin = 3;
// First parameter is the number of LEDs in the strand. The LED strips
// are 32 LEDs per meter but you can extend or cut the strip. Next two
// parameters are SPI data and clock pins:
LPD8806 strip = LPD8806(nLEDs, dataPin, clockPin);
// You can optionally use hardware SPI for faster writes, just leave out
// the data and clock pin parameters. But this does limit use to very
// specific pins on the Arduino. For "classic" Arduinos (Uno, Duemilanove,
// etc.), data = pin 11, clock = pin 13. For Arduino Mega, data = pin 51,
// clock = pin 52. For 32u4 Breakout Board+ and Teensy, data = pin B2,
// clock = pin B1. For Leonardo, this can ONLY be done on the ICSP pins.
//LPD8806 strip = LPD8806(nLEDs);
// Start up the LED strip
strip.begin();
// Update the strip, to start they are all 'off'
strip.show();
// Send a simple pixel chase in...
colorChase(strip.Color(127, 127, 127), 50); // White
colorChase(strip.Color(127, 0, 0), 50); // Red
colorChase(strip.Color(127, 127, 0), 50); // Yellow
colorChase(strip.Color( 0, 127, 0), 50); // Green
colorChase(strip.Color( 0, 127, 127), 50); // Cyan
colorChase(strip.Color( 0, 0, 127), 50); // Blue
colorChase(strip.Color(127, 0, 127), 50); // Violet
// Send a theater pixel chase in...
theaterChase(strip.Color(127, 127, 127), 50); // White
theaterChase(strip.Color(127, 0, 0), 50); // Red
theaterChase(strip.Color(127, 127, 0), 50); // Yellow
theaterChase(strip.Color( 0, 127, 0), 50); // Green
theaterChase(strip.Color( 0, 127, 127), 50); // Cyan
theaterChase(strip.Color( 0, 0, 127), 50); // Blue
theaterChase(strip.Color(127, 0, 127), 50); // Violet
// Fill the entire strip with...
colorWipe(strip.Color(127, 0, 0), 50); // Red
colorWipe(strip.Color( 0, 127, 0), 50); // Green
colorWipe(strip.Color( 0, 0, 127), 50); // Blue
rainbow(10);
rainbowCycle(0); // make it go through the cycle fairly fast
theaterChaseRainbow(50);
void rainbow(uint8_t wait) {
int i, j;
for (j=0; j < 384; j++) { // 3 cycles of all 384 colors in the wheel
for (i=0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel( (i + j) % 384));
strip.show(); // write all the pixels out
delay(wait);
// Slightly different, this one makes the rainbow wheel equally distributed
// along the chain
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for (j=0; j < 384 * 5; j++) { // 5 cycles of all 384 colors in the wheel
// tricky math! we use each pixel as a fraction of the full 384-color wheel
// (thats the i / strip.numPixels() part)
// Then add in j which makes the colors go around per pixel
// the % 384 is to make the wheel cycle around
strip.setPixelColor(i, Wheel( ((i * 384 / strip.numPixels()) + j) % 384) );
delay(wait);
// Fill the dots progressively along the strip.
void colorWipe(uint32_t c, uint8_t wait) {
int i;
strip.setPixelColor(i, c);
strip.show();
delay(wait);
// Chase one dot down the full strip.
void colorChase(uint32_t c, uint8_t wait) {
int i;
// Start by turning all pixels off:
for(i=0; i<strip.numPixels(); i++) strip.setPixelColor(i, 0);
// Then display one pixel at a time:
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c); // Set new pixel 'on'
strip.show(); // Refresh LED states
strip.setPixelColor(i, 0); // Erase pixel, but don't refresh!
delay(wait);
strip.show(); // Refresh to turn off last pixel
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (int i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i+q, 0); //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
for (int j=0; j < 384; j++) { // cycle all 384 colors in the wheel
strip.setPixelColor(i+q, Wheel( (i+j) % 384)); //turn every third pixel on
strip.show();
delay(wait);
/* Helper functions */
//Input a value 0 to 384 to get a color value.
//The colours are a transition r - g -b - back to r
uint32_t Wheel(uint16_t WheelPos)
byte r, g, b;
switch(WheelPos / 128)
case 0:
r = 127 - WheelPos % 128; //Red down
g = WheelPos % 128; // Green up
b = 0; //blue off
case 1:
g = 127 - WheelPos % 128; //green down
b = WheelPos % 128; //blue up
r = 0; //red off
case 2:
b = 127 - WheelPos % 128; //blue down
r = WheelPos % 128; //red up
g = 0; //green off
return(strip.Color(r,g,b));
thanks for your time.
Exue
