I have the RotEnc example from M2TkLib workign with my rotary encoder (a cheap one from DX) and my display (Nokia 5110), and my question below is based on that code.
- The first problem is that whatever I action I do with the rotary encoder (up/down) I need 2 clicks from trigger it. How do I make one click from the rotary encoder change the value in the RotEnc example by 1?
BTW, FWIW, I am using a Amtega1284 running at 20Mhz, and the encoder is connected to INT 0 and INT 1 (digital pins 10, 11 on the 1028). The encoder's push button is connected to digital pin 14.
In other words, how do I change the sensitivity of M2TkLib to my specific encoder?
- Does M2tkLib use interrupts? Can it be changed in order to do so?
Thank in advance.
