Hello -
I am trying to get a Makefile working, as I'm happier in a text editor than the IDE. I had one working for arduino version 0021, but when I upgraded to 0022, it's not working, and hoping someone can shed light on why - the error I get is:
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:7: undefined reference to setup' /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:10: undefined reference to loop'
(the full output is below).
So, a couple questions:
Is there a 'blessed' Makefile for version 0022? It seems that a bunch of stuff has changed between 0021 and 0022 - if anyone out there has a build file which references the latest Arduino version (0022) that would be awesome.
Can anyone shed any light on why the link step isn't seeing the setup and loop functions (these are defined in my Main.cpp, and look to be linked into the build).
Any help is greatly appreciated.
Thx.
The build output:
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/wiring_pulse.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/wiring_analog.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/pins_arduino.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/wiring.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/wiring_digital.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WInterrupts.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/wiring_shift.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/libraries/Wire/utility/twi.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/clock-arch.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/g2100.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/network.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/psock.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/stack.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/strings.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/timer.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/uip.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/uip_arp.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WMath.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs source/core.a ./lib/WiShield_user_contrib/WiServer.o
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -Os -lm -Wl,--gc-sections -mmcu=atmega328p -o source/Main.elf source/Main.o source/core.a
source/core.a(main.o): In function main': /Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:7: undefined reference to setup'
/Programs/Arduino/0022/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:10: undefined reference to `loop'
and the main pieces from the Makefile:
C_MODULES =
$(ARDUINO)/wiring_pulse.c
$(ARDUINO)/wiring_analog.c
$(ARDUINO)/pins_arduino.c
$(ARDUINO)/wiring.c
$(ARDUINO)/wiring_digital.c
$(ARDUINO)/WInterrupts.c
$(ARDUINO)/wiring_shift.c
$(INSTALL_DIR)/libraries/Wire/utility/twi.c
$(WISHIELD_PATH)/clock-arch.c
$(WISHIELD_PATH)/g2100.c
$(WISHIELD_PATH)/network.c
$(WISHIELD_PATH)/psock.c
$(WISHIELD_PATH)/stack.c
$(WISHIELD_PATH)/strings.c
$(WISHIELD_PATH)/timer.c
$(WISHIELD_PATH)/uip.c
$(WISHIELD_PATH)/uip_arp.c \
CXX_MODULES =
$(ARDUINO)/main.cpp
$(ARDUINO)/WMath.cpp
$(WISHIELD_PATH)/WiServer.cpp \
CXX_APP = Main.cpp
Place -I options here
CINCS = -I$(ARDUINO)
-I$(INSTALL_DIR)/libraries/Servo
-I$(INSTALL_DIR)/libraries/SPI
-I$(INSTALL_DIR)/libraries/Wire
-I$(INSTALL_DIR)/libraries/Wire/utility
-I./source
-I$(DEVICE_PATH)
-I$(METRO_PATH)
-I$(SOFTWARE_SERIAL_PATH)
-I$(WISHIELD_PATH) \
CXXINCS = -I$(ARDUINO)
