help with makes crittergram
i've make the crittergram by make and its seems to work but there is a issue with it. It seems to take pictures but some are either empty or i cant view them. I always tak out and put in the SD card when the arduino is off. If anyone has a idea why please post. Also t seems to maybe overwrite photos but im not sure.
here is a link to the project
I have used the following code without problems (with UNO and Ethernet shield). I deleted the PIR stuff (I don't have one at hand) and make the camera to take pictures every 10 seconds. Good luck.
#include <SPI.h>
#include <SD.h>
#define VC0706_PROTOCOL_SIGN 			0x56
#define VC0706_SERIAL_NUMBER 			0x00
#define VC0706_COMMAND_RESET			0x26
#define VC0706_COMMAND_GEN_VERSION		0x11
#define VC0706_COMMAND_TV_OUT_CTRL		0x44
#define VC0706_COMMAND_OSD_ADD_CHAR		0x45
#define VC0706_COMMAND_DOWNSIZE_SIZE		0x53
#define VC0706_COMMAND_READ_FBUF		0x32
#define FBUF_CURRENT_FRAME			0
#define FBUF_NEXT_FRAME				0
#define VC0706_COMMAND_FBUF_CTRL		0x36
#define VC0706_COMMAND_COMM_MOTION_CTRL		0x37
#define VC0706_COMMAND_COMM_MOTION_DETECTED	0x39
#define VC0706_COMMAND_POWER_SAVE_CTRL		0x3E
#define VC0706_COMMAND_COLOR_CTRL		0x3C
#define VC0706_COMMAND_MOTION_CTRL		0x42
#define VC0706_COMMAND_WRITE_DATA		0x31
#define VC0706_COMMAND_GET_FBUF_LEN		0x34
#define READ_DATA_BLOCK_NO			56
unsigned char 	tx_counter;
unsigned char 	tx_vcbuffer[20];
bool		tx_ready;
bool		rx_ready;
unsigned char 	rx_counter;
unsigned char 	VC0706_rx_buffer[80];
uint32_t 	frame_length=0;
uint32_t 	vc_frame_address =0;
uint32_t 	last_data_length=0;
File myFile;
const uint8_t SdChipSelect = 4;
char myFileName[16];
int myFileNr=1;
        SD.begin(SdChipSelect);
	VC0706_compression_ratio(66);
	delay(100);
	capture_photo("test.jpg");
  while (myFileNr != 0) {
    sprintf(myFileName, "CCC%03d.jpg", myFileNr);
    if (SD.exists(myFileName) == false) break;
    myFileNr++;
  capture_photo(myFileName);
  delay(10000);
void capture_photo(char myFileName[]) {
  	VC0706_frame_control(3);
	delay(10);
	if(SD.exists(myFileName)) SD.remove(myFileName);
	VC0706_frame_control(0);
	delay(10);
	rx_ready=false;
	rx_counter=0;
	Serial.end();			// clear all rx buffer
	delay(5);
	VC0706_get_framebuffer_length(0);
	delay(10);
	buffer_read();
	frame_length=(VC0706_rx_buffer[5]<<8)+VC0706_rx_buffer[6];
	frame_length=frame_length<<16;
	frame_length=frame_length+(0x0ff00&(VC0706_rx_buffer[7]<<8))+VC0706_rx_buffer[8];
	vc_frame_address =READ_DATA_BLOCK_NO;
	myFile=SD.open(myFileName, FILE_WRITE);
	while(vc_frame_address<frame_length){
		VC0706_read_frame_buffer(vc_frame_address-READ_DATA_BLOCK_NO, READ_DATA_BLOCK_NO);
		delay(9);
		rx_ready=false;
		rx_counter=0;
		buffer_read();
		myFile.write(VC0706_rx_buffer+5,READ_DATA_BLOCK_NO);
		vc_frame_address=vc_frame_address+READ_DATA_BLOCK_NO;
	vc_frame_address=vc_frame_address-READ_DATA_BLOCK_NO;
	last_data_length=frame_length-vc_frame_address;
	VC0706_read_frame_buffer(vc_frame_address,last_data_length);
	delay(9);
	rx_ready=false;
	rx_counter=0;
	buffer_read();
	myFile.write(VC0706_rx_buffer+5,last_data_length);
	myFile.close();
	delay(10);
void VC0706_read_frame_buffer(unsigned long buffer_address, unsigned long buffer_length)
	tx_vcbuffer[0]=VC0706_PROTOCOL_SIGN;
	tx_vcbuffer[1]=VC0706_SERIAL_NUMBER;
	tx_vcbuffer[2]=VC0706_COMMAND_READ_FBUF;
	tx_vcbuffer[3]=0x0c;
	tx_vcbuffer[4]=FBUF_CURRENT_FRAME;
	tx_vcbuffer[5]=0x0a;		// 0x0a=data transfer by MCU mode; 0x0f=data transfer by SPI interface
	tx_vcbuffer[6]=buffer_address>>24;			//starting address
	tx_vcbuffer[7]=buffer_address>>16;
	tx_vcbuffer[8]=buffer_address>>8;
	tx_vcbuffer[9]=buffer_address&0x0ff;
	tx_vcbuffer[10]=buffer_length>>24;		// data length
	tx_vcbuffer[11]=buffer_length>>16;
	tx_vcbuffer[12]=buffer_length>>8;
	tx_vcbuffer[13]=buffer_length&0x0ff;
	tx_vcbuffer[14]=0x00;		// delay time
	tx_vcbuffer[15]=0x0a;
	tx_counter=16;
	buffer_send();
void VC0706_frame_control(byte frame_control)
	if(frame_control>3)frame_control=3;
	tx_vcbuffer[2]=VC0706_COMMAND_FBUF_CTRL;
	tx_vcbuffer[3]=0x01;
	tx_vcbuffer[4]=frame_control;
	tx_counter=5;
	buffer_send();
void VC0706_get_framebuffer_length(byte fbuf_type)
	if(fbuf_type>1)fbuf_type=1;
	tx_vcbuffer[2]=VC0706_COMMAND_GET_FBUF_LEN;
	tx_vcbuffer[4]=fbuf_type;
	tx_counter=5;
	buffer_send();
void VC0706_uart_power_save(byte power_save_on)
	tx_vcbuffer[2]=VC0706_COMMAND_POWER_SAVE_CTRL;
	tx_vcbuffer[3]=0x03;
	tx_vcbuffer[4]=00;			//power save control mode
	tx_vcbuffer[5]=01;			// control by UART
	tx_vcbuffer[6]=power_save_on;			//start power save
	tx_counter=7;
	buffer_send();
void VC0706_compression_ratio(int ratio)
	if(ratio>63)ratio=63;
	if(ratio<13)ratio=13;
	int vc_comp_ratio=(ratio-13)*4+53;
	tx_vcbuffer[2]=VC0706_COMMAND_WRITE_DATA;
	tx_vcbuffer[3]=0x05;
	tx_vcbuffer[4]=01;		//chip register
	tx_vcbuffer[5]=0x01;	//data num ready to write
	tx_vcbuffer[6]=0x12;	//register address
	tx_vcbuffer[7]=0x04;
	tx_vcbuffer[8]=vc_comp_ratio; //data
	tx_counter=9;
	buffer_send();
void buffer_send()
	int i=0;
	for (i=0;i<tx_counter;i++)
		Serial.write(tx_vcbuffer[i]);
	tx_ready=true;
void buffer_read()
	bool validity=true;
	if (rx_ready)			// if something unread in buffer, just quit
		return;
	rx_counter=0;
	VC0706_rx_buffer[0]=0;
	while (Serial.available() > 0)
		VC0706_rx_buffer[rx_counter++]= Serial.read();
	if (VC0706_rx_buffer[0]!=0x76)
		validity=false;
	if (VC0706_rx_buffer[1]!=VC0706_SERIAL_NUMBER)
		validity=false;
	if (validity) rx_ready=true;
p
This works for me as well. Thank you.
I few minor things to keep in mind when doing this project. First upload the code without any shield. Once you have uploaded it, then wire it up. Also when testing the SD Card remove the power cord in order to avoid any corruption of the stored pictures.
