Hello Arduino Community,
I'm currently working on a project similar to a stamping machine, and I’ve encountered several issues I'd like your help with. Here's a summary of my setup and the problems I’m facing:
Hardware Configuration:
- Linear Stepper Motor: SGP1650-200
- Stepper Driver: DM542
- Manual Stepper Speed Controller: C30 CNC Stepper Motor Direction/Speed Controller
- Touch Screen: SEENGREAT 3.5-inch TFT LCD SPI Touch Screen
- Microcontrollers:
- Arduino UNO (dedicated to the LCD)
- Arduino MEGA 2560 ADK R3 (controls the stepper motor and communicates with UNO)
- Infrared Distance Sensor: TOF250
- Power Supply: 12V, 29A, 350W Switching Power Supply
System Architecture:
- The UNO is connected to the TFT LCD and handles the GUI interface.
- The MEGA receives commands via UART from the UNO.
- TOF250 IR sensor is connected to MEGA via
Serial2(TX2/RX2). - The MEGA controls the linear stepper motor via DM542 driver.
- The C30 controller is also connected to the motor for manual operation.
Problems I'm Facing:
- UNO ↔ MEGA UART conflicts — Sometimes the devices stop communicating or get stuck.
- DM542 ↔ MEGA issues — Even though the control code is uploaded, the motor doesn’t rotate.
- MEGA ↔ C30 control conflict — When both are connected, neither seems to work properly.
- I want manual (C30) and automatic (MEGA) control to coexist without interfering with each other.
What I'm Trying to Achieve:
- AUTO Mode (triggered from UNO LCD) — The motor moves down until TOF250 measures 10cm.
- CLEAR Mode — The motor moves up until 15cm.
- STOP Mode — Stops any ongoing motion immediately, overriding all other commands.
- C30 and MEGA should not interfere with each other (i.e., both connected, but not controlling at the same time).
I will attach the GUI code for UNO and the control code for MEGA if needed.
Can anyone help me identify what might be going wrong and how I can make both manual and automatic control work seamlessly?
Thanks in advance! ![]()
#include <SPI.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include "lcd_3inch5.h"
#include "lcd_gui.h"
#include "lcd_touch.h"
#include "fonts.h"
SoftwareSerial megaSerial(2, 3);
struct Rect { uint16_t x1, y1, x2, y2; };
Rect bandAuto, bandStop, bandClear;
bool wasPressed = false;
bool inRect(uint16_t x, uint16_t y, const Rect& r) {
return (x >= r.x1 && x <= r.x2 && y >= r.y1 && y <= r.y2);
void drawBand(const Rect& r, const char* label) {
Gui_draw_rectangle(r.x1, r.y1, r.x2, r.y2, BLACK, 2, EMPTY);
if (label && *label) {
uint16_t tx = r.x1 + (r.x2 - r.x1 - Font24.w * strlen(label)) / 2;
uint16_t ty = r.y1 + (r.y2 - r.y1 - Font24.h) / 2;
Gui_draw_str(tx, ty, label, &Font24, BLACK, WHITE);
void layoutInit() {
const uint16_t totalMargin = 40;
const uint16_t gapCount = 2;
const uint16_t GAP_V = 15;
uint16_t availableHeight = LCD_H - totalMargin - (gapCount * GAP_V);
uint16_t BOX_H = availableHeight / 3;
uint16_t x1 = 40;
uint16_t x2 = LCD_W - 40;
uint16_t y = totalMargin / 2;
bandAuto = {x1, y, x2, (uint16_t)(y + BOX_H)};
y += BOX_H + GAP_V;
bandStop = {x1, y, x2, (uint16_t)(y + BOX_H)};
y += BOX_H + GAP_V;
bandClear = {x1, y, x2, (uint16_t)(y + BOX_H)};
void drawUI() {
LCD_Clear(WHITE);
drawBand(bandAuto, "Auto");
drawBand(bandStop, "Stop");
drawBand(bandClear, "Clear");
void showCenterText(const char* msg) {
uint16_t textW = Font24.w * strlen(msg);
uint16_t tx = (LCD_W - textW) / 2;
uint16_t ty = (LCD_H - Font24.h) / 2;
Gui_fill_color(0, ty - 5, LCD_W, ty + Font24.h + 5, WHITE);
if (msg && *msg) {
Gui_draw_str(tx, ty, msg, &Font24, BLACK, WHITE);
void sendCommand(const char* cmd) {
megaSerial.write(cmd);
megaSerial.begin(9600);
Lcd_Gpio_Init();
SPI.begin();
Lcd_Init();
TP_Init();
layoutInit();
drawUI();
uint8_t pressed = TP_Scan(0);
if (pressed && !wasPressed) {
uint16_t tx = tp_dev.x[0];
uint16_t ty = tp_dev.y[0];
if (inRect(tx, ty, bandAuto)) {
Serial.println("AUTO");
showCenterText("Moving...");
sendCommand("A");
else if (inRect(tx, ty, bandStop)) {
Serial.println("STOP");
showCenterText("STOP!");
sendCommand("S");
else if (inRect(tx, ty, bandClear)) {
Serial.println("CLEAR");
showCenterText("Clear...");
sendCommand("C");
else if (!pressed && wasPressed) {
showCenterText("");
wasPressed = pressed;
This is ARDUINO UNO's GUI code
#define STEP_PIN 9
#define EN_PIN 10
#define STEP_DELAY 700
volatile char currentCommand = '\0';
String distanceStr = "";
int currentDistance = -1;
const int DOWN_TARGET = 10;
const int UP_TARGET = 15;
Serial1.begin(9600);
Serial2.begin(9600);
pinMode(DIR_PIN, OUTPUT);
pinMode(STEP_PIN, OUTPUT);
pinMode(EN_PIN, OUTPUT);
digitalWrite(EN_PIN, LOW);
Serial.println("MEGA started");
readDistanceSensor();
readUnoCommand();
if (currentCommand == 'A') {
moveToTarget(DOWN_TARGET, true);
} else if (currentCommand == 'C') {
moveToTarget(UP_TARGET, false);
delay(10);
void readUnoCommand() {
if (Serial1.available()) {
char cmd = Serial1.read();
if (cmd == 'A' || cmd == 'C' || cmd == 'S') {
currentCommand = cmd;
Serial.print("Received command: ");
Serial.println(cmd);
void readDistanceSensor() {
while (Serial2.available()) {
char c = Serial2.read();
if (c == '\n') {
currentDistance = distanceStr.toInt();
distanceStr = "";
Serial.print("Distance: ");
Serial.print(currentDistance);
Serial.println(" cm");
} else if (isDigit(c)) {
distanceStr += c;
void moveToTarget(int target, bool goingDown) {
Serial.println(goingDown ? "Moving Down" : "Moving Up");
digitalWrite(DIR_PIN, goingDown ? HIGH : LOW);
while (true) {
if (currentCommand == 'S') {
Serial.println("STOP command received → Stopping movement");
if (currentDistance > 0) {
if ((goingDown && currentDistance <= target) ||
(!goingDown && currentDistance >= target)) {
Serial.println("Target distance reached → Stopping");
digitalWrite(STEP_PIN, HIGH);
delayMicroseconds(STEP_DELAY);
digitalWrite(STEP_PIN, LOW);
I really want to solve this problem plz sombody help me...
and if you want my e-mail or instagram, I can give you.
i can give you pictures that you want
