Help with memory usage
I have this that's been pieced together and just a little bit more to add. I am almost out of memory already, can someone look over it and tell me what is using so much and if I can save some memory usage somewhere?
Thanks,
Kevin
Code:
#include "U8glib.h"
// constructor call for display
U8GLIB_ST7920_128X64 u8g(13, 11, 10, U8G_PIN_NONE); // SPI Com: SCK = en = 13, MOSI = rw = 11, CS = di = 0
void draw(void)
// graphic commands to redraw the complete screen should be placed here
void setup(void) {
// flip screen / rotated for current display
u8g.setRot180();
// set SPI backup if required / not required with current display
//u8g.setHardwareBackup(u8g_backup_avr_spi);
void loop(void) {
// picture loop
u8g.firstPage();
do {
draw();
if(millis() < 5000) // It's been less than 5 seconds since reset
u8g.setFont(u8g_font_fub30);
u8g.drawStr( 20, 32, "K&D");
u8g.setFont(u8g_font_unifont);
u8g.drawStr( 18, 45, "InnoVations");
u8g.setFont(u8g_font_baby);
u8g.drawStr( 17, 60, "Go With The Digital Flow");
u8g.drawStr( 0, 12, "FLOW RATE");
u8g.drawStr( 0, 40, "Num.");
u8g.drawStr( 0, 60, "BATTERY %");
} while( u8g.nextPage() );
// rebuild the picture after some delay
graphics libraries tend to be huge, containing (among other things) large font tables. And you're using THREE of them...
If you're going to display "K&D Innovations Go with the digital flow" only as a power-on logo, you'd be much better off figuring out how to save and display it as a bitmap.
Ok Thanks!
Didn't realize they used so much memory. How about just straight text option with U8GLIB? I think it is called U8X8.
If not may just kill for now until I can figure out a bit map option.
Kevin
Decided just to keep it basic. It's just a little project I am playing around with and trying to learn.
Thanks for the help!
Kevin
