help with MIDI patch
hi all, I am trying to build a MIDI keyboard with arduino. I have installed midi firmware and so on.
Every think seems to work, but I have a problem with the sketch. Now I am testing with 3 buttons, but finally I want to make it with 14.
So if I upload this sketch:
#include <MIDI.h>
const byte keys[] = {8, 9, 10};
const byte notes[] = {36, 38, 40};
const byte LED = 13;
boolean kPress[3];
boolean note[3];
void  setup() {
  for (byte set=0; keys[set]!=0; set++){
    pinMode(keys[set], INPUT);
  pinMode(LED, OUTPUT);
  MIDI.begin();
  kPress[0] = digitalRead(keys[0]);
  if (kPress[0] == HIGH){
    digitalWrite(LED, HIGH);
    if(!note[0]){
       MIDI.sendNoteOn(notes[0],127,1);
       note[0] = HIGH;
  else{
    digitalWrite(LED,LOW);
    if(note[0]){
      MIDI.sendNoteOff(notes[0],0,1);
      note[0] = LOW;
  kPress[1] = digitalRead(keys[1]);
  if (kPress[1] == HIGH){
    if(!note[1]){
       MIDI.sendNoteOn(notes[1],127,1);
       note[1] = HIGH;
  else{
    if(note[1]){
      MIDI.sendNoteOff(notes[1],0,1);
      note[1] = LOW;
  kPress[2] = digitalRead(keys[2]);
  if (kPress[2] == HIGH){
    if(!note[2]){
       MIDI.sendNoteOn(notes[2],127,1);
       note[2] = HIGH;
  else{
    if(note[2]){
      MIDI.sendNoteOff(notes[2],0,1);
      note[2] = LOW;
  delay(50);
everything works fine
if I try to make a shorter variant with a for loop:
#include <MIDI.h>
boolean kPress[sizeof(keys)] = {LOW};
boolean note[sizeof(notes)] = {LOW};
void  setup() {
  MIDI.begin();
  for (byte i=0; keys[i]!=0; i++){
    kPress[i] = digitalRead(keys[i]);
    if (kPress[i] == HIGH){
      if(!note[i]){
         MIDI.sendNoteOn(notes[i],127,1);
         note[i] = HIGH;
    else{
      if(note[i]){
        MIDI.sendNoteOff(notes[i],0,1);
        note[i] = LOW;
  delay(100);
it glitches, I mean when I press the button it pushes sequence of notes fast one after another. If I follow the steps in the code everything looks the same as in the first patch. What is wrong?
I am new to programing and arduino, can anyone help?
Thanks in advance
what does keys equal when i=3?
Oh, :~ stupid!
Thanks a lot :slight_smile: !!!
