Help with Midi Processing - 2560 mega
Hello all... I am having a hard time getting a midi (TX0) signal to come out of my project. The schematic and script I have been given appear to line up correctly and I have actually gotten this project to start working on a previous computer (though it was years ago). I get signal when I plug the board in via usb and I see the TX LED lighting up when it is plugged in via usb but when I try to only plug the board in via dc power I don't get any TX signal.
I have to make this project work via midi jack only so making it work via a usb and then using "hairless" to convert the signal will not work for my case... Please help me as I know this project has worked before... I am super puzzled...
Schematic
Script
#include <SoftwareSerial.h>
SoftwareSerial midi (7,8); ///RX TX
int clearbtn = 14;
int recordbtn = 2;
int stopbtn = 3;
int track1btn = 5;
int track2btn = 6;
int track3btn = 11;
int modebtn = 4;
int undobtn = 13;
int led = 9;
int toggle1 = 0;
int toggle2 = 0;
int toggle3 = 0;
int toggle4 = 0;
int toggle5 = 0;
int toggle6 = 0;
int toggle7 = 0;
int toggle8 = 0;
int mode = 0;
void setup(){
  pinMode (clearbtn, INPUT_PULLUP);
  pinMode (undobtn, INPUT_PULLUP);
  pinMode (recordbtn, INPUT_PULLUP);
  pinMode (stopbtn, INPUT_PULLUP);
  pinMode (track1btn, INPUT_PULLUP);
  pinMode (track2btn, INPUT_PULLUP);
  pinMode (track3btn, INPUT_PULLUP);
  pinMode (modebtn, INPUT_PULLUP);
  pinMode (led, OUTPUT);
  digitalWrite(led, HIGH);
  delay(250);
  digitalWrite(led, LOW);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  delay(250);
  midi.begin(31250);
void loop(){
  if (digitalRead(undobtn) == LOW && toggle1 == 0){
    toggle1 = 1;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x41);
      midi.write(0x01);
      // delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x36);
      midi.write(0x01);
      // delay(300);
  if (digitalRead(undobtn) == HIGH && toggle1 == 1){
    toggle1=0;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x41);
      midi.write((byte)0x00);
      delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x36);
      delay(300);
  if(digitalRead(clearbtn) == LOW && toggle2 == 0){
    toggle2 = 1;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x01);
      midi.write(0x45);
      //delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x37);
      midi.write(0x45);
      //delay(300);
  if(digitalRead(clearbtn) == HIGH && toggle2 == 1){
    toggle2 = 0;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x01);
      delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x37);
      delay(300);
  if(digitalRead(recordbtn) == LOW && toggle3 == 0){
    toggle3 = 1;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x10);
      midi.write(0x45);
      //delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x35);
      midi.write(0x45);
      // delay(300);
  if(digitalRead(recordbtn) == HIGH && toggle3 == 1){
   toggle3 = 0;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x10);
      delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x35);
      delay(300);
  if(digitalRead(stopbtn) == LOW && toggle4 == 0){
    toggle4 = 1;
    ///Serial.println("mute/stop");
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x07);
      midi.write(0x45);
      //delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x34);
      midi.write(0x45);
      //delay(300);
  if(digitalRead(stopbtn) == HIGH && toggle4 == 1){
    toggle4 = 0;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x07);
      delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x34);
      delay(300);
  if (digitalRead(track1btn) == LOW && toggle5 == 0){
    toggle5 = 1;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x14);
      midi.write(0x01);
      // delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x33);
      midi.write(0x01);
      //  delay(300);
  if (digitalRead(track1btn) == HIGH && toggle5 == 1){
    toggle5 = 0;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x14);
      delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x33);
      delay(300);
  if (digitalRead(track2btn) == LOW && toggle6 == 0){
    toggle6 = 1;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x15);
      midi.write(0x01);
      // delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x32);
      midi.write(0x01);
      // delay(300);
  if (digitalRead(track2btn) == HIGH && toggle6 == 1){
    toggle6 = 0;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x15);
      delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x32);
      delay(300);
  if (digitalRead(track3btn) == LOW && toggle7 == 0){
    toggle7 = 1;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x16);
      midi.write(0x01);
      //  delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x31);
      midi.write(0x01);
      // delay(300);
  if (digitalRead(track3btn) == HIGH && toggle7 == 1){
    toggle7 = 0;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x16);
      delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x31);
      delay(300);
  if (digitalRead(modebtn) == LOW && toggle8 == 0){
    toggle8 = 1;
    if(mode == 0){
      midi.write(0x90);
      midi.write(0x17);
      midi.write(0x01);
      // delay(300);
    if(mode == 1){
      midi.write(0x90);
      midi.write(0x30);
      midi.write(0x01);
      //  delay(300);
  if (digitalRead(modebtn) == HIGH && toggle8 == 1){
    toggle8 = 0;
    if(mode == 0){
      mode = 1;
      midi.write(0x90);
      midi.write(0x17);
      delay(300);
    else if(mode == 1){
      mode = 0;
      midi.write(0x90);
      midi.write(0x30);
      delay(300);
Be more precise with the labels and pin numbers, that should be all.
Please don't call it TX0, it is just a "TX" signal.
Your sketch shows the parameter order RX, TX, that is very good.
SoftwareSerial midi (7,8); // RX TX
Pin 7 will be RX and pin 8 will be TX.
Then check the hardware, which pin is the midi output ?
How do you know that pin 14 is A2 ? Please use the normal labels, such as A2, A4, and so on.
const int clearPin = A2;
const int undoPin = A4;
const int track3Pin = A5;
It is safer with an extra 10k resistor from /RESET to VCC.
Where are the decoupling capacitors ?
Your Mega has 4 serial ports; why do you use software serial?
The TX and RX leds are only used in communication with the PC; any other serial communication will not show activity on those leds.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
I'm sorry for posting in the wrong forum, thank you for re-locating it.
This is someone else's sketch that I got from an instructable... They built this project on a nano I believe... This same pin assignment should definitely work on a Mega 2560 though... right? I had the 2560 laying around from another project.
I decided to just assign everything to an analog pin instead...
SoftwareSerial midi (A11,A12); ///RX TX
int clearbtn = A2;
int recordbtn = A3;
int stopbtn = A4;
int track1btn = A5;
int track2btn = A6;
int track3btn = A7;
int modebtn = A8;
int undobtn = A9;
int led = A10;
