I'm trying to use the blink without delay example in my code. Reading through the example I thought I understood how it worked but cannot apply it (so maybe not!). I wanted to change colors of an LED at a specific time while moving a servo arm so I cannot use the delay() command. I know the code to turn my Led's on works, but cannot get it to work with my current code. Below is a function I'm trying to get it to work with. Any advice appreciated.
void Scene_14() //The name of my function
unsigned long previousMillis = 0;
const long interval = 9200; //I want to LED's to turn on after 9200 mS
if(currentMillis - previousMillis >= interval) { //This is the part that's not working
// save the last time you blinked the LED
for (int i = 0; i < NUM_LEDS; ++i) //This turns the LED's 0 to 14 on
leds[i] = CRGB::Red;
FastLED.show();
delay(2700);
FastLED.clear (); //TURN LED's off
FastLED.show();
SWITCH_SLOW(); //This function moves a servo
delay(12000);
FastLED.show();
You need to give a better description of what goes wrong. What do you expect it to do? And what does it do.
You still have delays; they will seriously interfere with the millis() based timing When you call Scene_14 again, those 9200 ms are long gone.
The main problem currently is that previousMillis is not a static variable and hence every time that you enter Scene_14, it's value is set to 0. Change unsigned long previousMillis = 0; to static unsigned long previousMillis = 0; for starters
If I understand the code correctly, you want the leds to be on after 9200 ms for a duration of 2700 ms? If so, I suggest that you keep a variable that holds the state of the leds. You also need to change the interval variable so it's not a const but a static variable.
The first part of your code
// remember the interval
// initial value 9200 ms
static unsigned long interval = 9200; //I want to LED's to turn on after 9200 mS
// keep track of the state of the leds
// initial value false so first time a timeout occurs leds will be switched on
static bool fLedOn = false;
if (currentMillis - previousMillis >= interval) //This is the part that's not working
// if leds are off
if (fLedOn == false)
FastLED.show();
// indicate leds are on
fLedOn = true;
// set ON duration
interval = 2700;
// if leds are on
FastLED.show();
// indicate leds are off
fLedOn = false;
// set OFF duration
interval = 9200;
// other stuff here
Test this without the other stuff tiill you are confident that it works. Next I suggest that you place the blink part in a separate function, e.g. led_14 and call that from Scene_14.
non-blocking blink 14 leds
void led_14()
// if leds are off
FastLED.show();
fLedOn = true;
// set ON duration
interval = 2700;
// if leds are on
FastLED.show();
fLedOn = false;
// set OFF duration
interval = 9200;
Your Scene_14 could now look like
void Scene_14()
// blink the leds
led_14();
// run the servo
servo_14();
I hope this gets you on track.
PS: I'm not familiar with the FastLed library so had to base that part on what you gave.
